I got a problem with this 383 swap
Old Jul 22, 2004 | 10:46 AM
Spdfrk1990's Avatar
Ok im told i need to switch to a t56 cause i cant find a HD t5 or parts newhere to hold a 383. So i have had my engine balanced for the t5 flywheel alrdy. It doesnt look like they added any weight to the flywheel tho just the crank and balancer. Do you think it would throw it off balance to get a t56 flywheel?
Old Jul 22, 2004 | 04:21 PM
whiteshadow87's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 1991 L-98
Transmission: 700R-4
The Tremec TKO tranny will hold 525lb/ft, but its $2,059.00 out of the year one catalog.
Old Jul 22, 2004 | 05:16 PM
Spdfrk1990's Avatar
Thats not bad i wonder if any1 else sells it and can you pick different gear ratios.
Old Jul 22, 2004 | 05:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need to know if the engine was set up for stock 400 balance; or for stock 305/350 balance (neutral); or "custom balanced" using the existing flywheel.
Does your 383 have a 1-piece rear main seal, or 2-piece? Is it a stock GM carnk, or aftermarket? How long are the rods?
There's too many possibilities for anyone to be able to guess at it, even looking at the motor from the outside.
Old Jul 22, 2004 | 05:50 PM
Spdfrk1990's Avatar
Its a zz4 block,scat crank,6.0 h beam eagle rods,the summit race balancer its for a internal or external balance. It had a weight bolted to it and they did change that weight some and add weight to the crank but i didnt see anything done to the flywheel.The flywheel is a new stock unit.
Old Jul 22, 2004 | 06:02 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
http://www.g-forcetransmissions.com/
Old Jul 22, 2004 | 06:08 PM
Spdfrk1990's Avatar
I dunno about that kit. I should of just decided to go with a t56 in the first place i like top end anyway and want a 6th gear.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
