rebuilding 305 T.P.I. on a budget
Old Jul 30, 2004 | 12:29 PM
DA 89 CAMARO's Avatar
Car: 89 RS,97 Z28
Engine: 305 T.B.I,350 LT1
Transmission: T5,T56
I recently bought my first camaro for $600 bucks.it came with a T.B.I. 305,but i went to the junk yard and found a T.P.I.305,its pretty much complete and i want to swap them.I still want to have a daily driver but i want to add some performanceparst to the engine where would my money be best spent?
Old Jul 31, 2004 | 02:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Getting the entire TPI engine, harness, exhaust, computer, fuel tank (at least the fuel pump), and everything associated with the TPI engine that's different from the TBI would probably set you back again as much as you paid for the car. It would be a decent improvement, though.
Improving that would probably be cheaper than trying to improve the TBI engine/system as-is.
Old Aug 5, 2004 | 07:29 PM
my 82 trans am's Avatar
Car: 1990 Camaro RS
Engine: 5.0 liter TBI
Transmission: Borg Warner T-5
i have a 90 rallysport camaro thats in showroom condition, its equiped with the TBI. i think its a great set up, its simple, efficiant,
and very easy to work on. but you would only get maybe a 5-10 hp difference. you could do a few things to the tbi to get that.
Old Aug 5, 2004 | 08:56 PM
ljnowell's Avatar
i have a 90 rallysport camaro thats in showroom condition, its equiped with the TBI. i think its a great set up, its simple, efficiant,and very easy to work on. but you would only get maybe a 5-10 hp difference. you could do a few things to the tbi to get that
I think that I would take the TPI over the crappy heads and injection of the TBI anyday. Well, I think Iwould rather have a carb than either one though.
Old Aug 5, 2004 | 10:05 PM
89FormulaLS2's Avatar
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
TBI 350 rated at 170ish HP
TPI 305 rated at 205ish HP
TPI 350 rated at 240ish HP
Personally, if I was you I wouldn't bother spending the money to go from a 305 TBI to a 305 TPI. I'd save my money a get a 350 TPI for probably around $100 more than a 305 TPI will cost you. THAT would be worth the hassle and expense of what you are trying to do, and would give you the best "bang" for your buck.
Old Aug 5, 2004 | 11:38 PM
Car: 89 RS,97 Z28
yeah.i think im going to wait till i get a 350block.i have been doing some reading since i posted the last tread and i no longer want to rebuild the 305 but now i got two 305 block's
Old Aug 6, 2004 | 08:36 AM
Not sure what it would cost, but the 305 and 350 block is supposed to be the same. Supposedly, you can just bore out the 305 and turn it into a 350 - if you're going to build the whole engine anyway, you might want to do some research on that. Since you've already got two blocks, might be the cheapest way to go at this point. Don't know if it'll work, but if it was me I'd check it out.
Old Aug 6, 2004 | 10:30 AM
ljnowell's Avatar
The 305 cannot be bored out to a 350. It can be bored, at best, .060 over. That makes roughly 315, I think. The 350 and 305 share the same stroke (3.48). YOu can stroke the 305 to 334, but you will spend as much as you would on a 383, so why bother? Get rid of both of them and get a 350.
Old Aug 6, 2004 | 11:33 AM
There you have it!
The 350 still sounds like the best route to me. Time to sell the 305's??!!
Old Aug 6, 2004 | 01:11 PM
Car: 89 RS,97 Z28
I think that i'ts time for me to look for a new block.just one more question.what year block should i be looking for?I've heard that it has to be one that had a roller cam.is that true?
Old Aug 6, 2004 | 01:21 PM
five7kid's Avatar
'87-up have the roller cam and one-piece rear main seal. If possible, I'd try to maintain that.
Old Aug 6, 2004 | 01:40 PM
Car: 89 RS,97 Z28
thank's for the help.saved me from making another dumb mistake.I almost got a 350 from a 72 malibu yeasterday
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
someone972
Aug 30, 2015 12:52 AM
