FI v6 to carb v8 throttle linkage
Old Aug 1, 2004 | 12:16 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I'm looking into doing a possible 2.8 fi to carb v8 swap. I have a v8 donor car (the car in sig). How hard is it to make the throttle linkage work right if I were to swap the v8 for the 6?
Old Aug 1, 2004 | 01:01 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
A lot easier to just use the carb'ed V8 throttle cable.
Old Aug 1, 2004 | 01:34 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Alright, thats what i thought. Its not hard to remove/install is it?
Old Aug 1, 2004 | 02:59 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
The one in the V6 car will work. I am using the V6 cable on my carb'ed V8.
Old Aug 1, 2004 | 04:54 PM
ljnowell's Avatar
I went from mpfi 2.8 to carb'd 350, and retained the stock throttle cable, it works perfectly.
Old Aug 2, 2004 | 12:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
2.8 carbed cable won't work on a carbed V8, though (I understand that wasn't the question here).
I think I'd still go for V8 throttle and TV cables.
Old Aug 2, 2004 | 05:27 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I wont run a tv cable. This is a drag only car, no need to downshift, just bang the gears of the built th350.
Old Aug 2, 2004 | 06:14 PM
five7kid's Avatar
Well, you never said anything about that...
Old Aug 3, 2004 | 01:43 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
ME Tw0
Old Aug 4, 2004 | 08:51 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yes they work just fine they are just a little too long and you have to bunch it up no big deal thou
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RedLeader289
May 28, 2019 01:47 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
customblackbird
Oct 1, 2015 04:30 PM
Damon
Sep 26, 2015 04:29 PM
