Diesil Engine
Old Aug 4, 2004 | 03:32 PM
ridemylightning's Avatar
Diesil Engine
Is it possible, or that difficult to put a diesel engine in a 3rd gen?
Old Aug 4, 2004 | 04:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably no harder than it would be to put any other engine into a thirdgen. A lot of it would depend on which diesel you picked.
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There are just as many diesel egnines out there as there are gas engines. What do you want to use. It will be a custom swap that will cost an arm and a leg. Why do you want a diesel engine?
Old Aug 4, 2004 | 04:25 PM
I was just curious to know. We had talked about bio-diesal made from vegetable oil in class a few days ago, and so I was just curious about it. Not something I'd probably do, but just out of curiousity's sake.
Old Aug 4, 2004 | 04:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah diesels will burn just about anything. In a pinch you can run a diesel on its own crankcase oil.
Old Aug 4, 2004 | 09:04 PM
jeep_guy's Avatar
what would you do once you start runnin low on that fuel
but anyway i have thought about that type of thing before, nothing i would ever do though, but it would be cool as an exhibition vehicle for biodiesel at farm shows around here they have a dodge ram that runs on biodiesel and i think a third gen with a duramax would be way cooler
Old Aug 4, 2004 | 09:10 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
diesel engine in a 3rd gen???? what???? why????
Old Aug 4, 2004 | 09:55 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
how about a diesl from a kenworth truck
Old Aug 4, 2004 | 10:11 PM
THEGENERAL's Avatar
why not ...LOL......how about we put a harley engine in one too...LOL...
sorry i appologize .....i shouldnt be like this but it just sounds so absurd to do
Old Aug 4, 2004 | 10:13 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
how about a Lawn Boy Engine
Old Aug 4, 2004 | 10:14 PM
THEGENERAL's Avatar
nah too expensive id go with a briggs and straton and buy one of those jegster kits for it ....
Old Aug 5, 2004 | 08:39 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'l take an M1 engine for $10,000.00 Alex....
Old Aug 5, 2004 | 09:24 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
turbo diesel + propane injection + 4,500+ lb truck = low 11second daily driver with 40+mpg.
just imagine what it could do in a thousand pound lighter car.
Old Aug 5, 2004 | 07:25 PM
THEGENERAL's Avatar
yeah especially without a full strong frame under it could you imagine what it could do i sure could...LMAO...those things put out some massive torque
Old Aug 5, 2004 | 09:17 PM
biff85ta's Avatar
Car: 04 Vette
The old 6.2 diesel would probably be fairly easy to get in the car as it is based on the chevy big block.
Old Aug 5, 2004 | 09:25 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
7.3 Powerstroke + Banks Six shooter in highest modem = 400hp 700 lb ft torque.
Normal modem 225 hp 520 lb ft torque = 21-25 mpg.
Old Aug 5, 2004 | 11:34 PM
THEGENERAL's Avatar
but could you imagine the looks your gonna get from people when they hear that engine clattering ...LOL... there gonna call you a R E D N E C K ............lol
Old Aug 17, 2004 | 11:29 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
78-85 oldsmobile 5.7L diesel would go in the easiest but the exhaust and fuel system and starting and charging systems wiring issues, bellhouisng bolt pattern problems, gotta have another battery on board,
the olds 350 diesle was an olds 350 gas engine but with different heads and piston so that it could have 22:1 compression, and a different starter too,
also diesel auto trans converters were not the same as gas ones, they have different stall speed altogether,
not good for a gas engine
find this engine in caprices and olds and buicks and wagons 78-up
ive had a few, one was an 83 capprice 4 door built in canada, i had to scrap it cuz someone ruined wiring and fuel system trying to convert it to chevy 350
thats the cause of scrap/shredder death of most all GM RWD 78-85 diesel 5.7L cars.
ppl who think they can convert something that really cant or shouldnt
good luck
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
