LT1 Underhood Fuse Block?
Old Aug 22, 2004 | 04:53 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Where does the underhood fuse block get it's power from? I'm trying to wire up my '88 Trans Am with a '94 LT1/T56 and the motor came with the underhood fuse block harness also.
The PCM gets the power for the injectors from the 2 7.5 Amp fuses in the underhood fuse block, and power from the Ignition fuse (10 amp) too. I have the 4th gen C100 connected to the engine harness I just don't know where the power will come from.
There's a lot of fat red wires that go to the relays in the underhood fuse block....do these fuses (9,10,and 11) get power from those red wires too?
Old Aug 23, 2004 | 12:13 PM
Projek: 85 3800's Avatar
Car: 85 Firebird
Engine: 3800 Series II
Your best bet might be getting a holy book haynes for the wiring schematics on that engine. Also gives you info on the new motor. (but you knew that already)
Alternative could be going to a dealer & ask to see a wiring schematic for the 94 car. IT helped me tremendously w/my swap and it was free
Old Aug 23, 2004 | 12:34 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im not sure since I never even used that extra wiring harness. Might want to check www.shbox.com.
Old Aug 23, 2004 | 03:30 PM
Car: 85 Firebird
all the 4th gens I've seen have had fuse/relay boxes on each side of the engine bay.
Old Aug 23, 2004 | 08:40 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Well I've got my thirdgen manual that goes from 82-94. And I've got the '94 Chiltons. I work at a dealership and can have access to those, I just need to know how ya'll hooked up power for your injectors?
I cut most of the wires to where all I have going to the underhood fuse block is the fat red wires that go to the junction block and the 4th gen C100 wires.
Old Aug 24, 2004 | 12:28 AM
pasky's Avatar
I just spliced into the pink wire onto the injectors and gave it power from another wire that got power after the key was turned.
gta892000
Aug 11, 2019 11:16 AM
New2Chevy
Sep 28, 2015 12:35 AM
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
