2.8 starter on sbc?
Old Aug 27, 2004 | 09:16 AM
Egg83's Avatar
Car: 85 Firebird
Engine: 355 Vortec TPI
Transmission: 700r4 with Pro-Built goodies
Axle/Gears: LS1 3.42 Posi Disc
2.8 starter on sbc?
Hey all, I am currently in the midst of my v6 to v8 swap in my 85 bird. I got the ol 2.8 out and took the starter off for a core on my new starter. I was noticing that it has the same mounting points/bolts and fits almost perfectly on my 355. Will my 2.8 starter work with my 355 and 153 tooth flywheel? Has anyone else experienced this? Thanks for the help. -Bob
Old Aug 27, 2004 | 09:36 AM
Parrydise7's Avatar
I don't think so. Do you have a knowledgeable dealer parts guy that you can call?
Old Aug 27, 2004 | 10:15 AM
Egg83's Avatar
Car: 85 Firebird
I am a tech at a ford dealership and there is a chevy dealership like 3 blocks down, ill have the parts guys call and ask about it. I was thinking that it could be the same starter but maybe it has different terminal arrangements, so it would have a different part number. If that is the case i was thinking i could modify the cables to work with the starter.
Old Aug 27, 2004 | 04:52 PM
Projek: 85 3800's Avatar
Car: 85 Firebird
Engine: 3800 Series II
terminals shouldn't be an issue, it will be the tooth count on the flywheel that makes the difference. Might just want to go down to a parts store & compare them to each other, worse case scenario, count the teeth on the 2.8.
Old Aug 27, 2004 | 08:01 PM
Parrydise7's Avatar
Just check the part numbers. If it is the same p/n (and I am 99% certain it is not because that 2.8 is metric), they are interchangeable. I wanted one of those fancy chrome starter for my 2.8. IIRC, and it has been a long time, the guy at the dealer (who was sharp) said the sbc chrome starter would not work on a 2.8.
Old Aug 30, 2004 | 08:23 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
go to parts store ask for both starters and count the teeth on each, if the same go for it.
if the v8 one is longer it may have a different starter motor that has more torqe to turnover the more rotating mass
try it, if its not enough no harm, if it is thats money in your pokect.
Old Aug 30, 2004 | 10:23 PM
Egg83's Avatar
Car: 85 Firebird
I might as well buy a V8 one if the starting torque is more anyways. Damn, i was hoping that they were the same size, now i have to wait a couple more days to get a starter so that i can start my new engine! A reman 153 tooth starter is like $50 anyways, oh well big loss. Thanks guys
Old Sep 1, 2004 | 04:18 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The 2.8 starter motor will be overloaded trying to crank and engine double the discplacement. This will cause high current draw and low cranking speed, and probably drain your battery quicker than if you had a larger starter motor. The high current draw will make short work of the 2.8 starter motor and you'll be replacing it again. Use the larger starter motor intended for the 305 engine.
86maro_252
Oct 10, 2015 06:52 PM
Zane Story
Oct 8, 2015 12:40 PM
spartanreaper
Sep 25, 2015 07:22 PM
sahlomonic
Sep 20, 2015 07:15 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
