LG4 and T5?
Old Aug 29, 2004 | 12:55 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
LG4 and T5?
Are there certain T5's that wil bolt to an LG4 (305 right?)
I been talkin about swapping to a 3.4 but I do not mind switching to a v8 (in fact its originally what I wanted) if it means I don't need to change out my transmission. Now if my T5 will bolt to the 305, then all I would probably need to do is have the transmission rebuilt to handle the power.
Is that possible? I"d rather have 305 than v6
Old Aug 29, 2004 | 02:36 PM
TexasLT1's Avatar
Car: '92 RS
A V6 T-5 will not work with a V8 without some work
Old Aug 29, 2004 | 02:38 PM
Engine: 355 TPI
So would there be a way to have the transmission fixed up to handle more power and like an adapter or something to get it to bolt to the 305?
Old Aug 29, 2004 | 03:52 PM
TexasLT1's Avatar
Car: '92 RS
The bellhousing isn't the only problem, the input and I think output shaft are different, as well as the clutch. Just get a T-5 from a 305 and you'll be alright.
Old Aug 29, 2004 | 04:10 PM
Engine: 355 TPI
Ok so I get a t5 from a 305..... how much would it be able to handle? Cuz I'd want to mod the 305 a lil and attempt to get around 200HP/300 torque outta it.
What about driveshaft length? Since this is a v6 1984 camaro would i need a longer/shorter one for the 305 if i swap it in?
Old Aug 29, 2004 | 04:46 PM
TexasLT1's Avatar
Car: '92 RS
Get a World Class T-5 from I think an '89 or higher and you'll be fine. Driveshaft doesn't change.
Old Aug 29, 2004 | 04:48 PM
Engine: 355 TPI
i guess i'll phone in some junkyards to see if they have any
RazorN8
Jan 7, 2022 11:44 AM
podiatra
Aug 31, 2015 09:53 AM
ambainb
Aug 29, 2015 12:43 AM
85ws6TA
Jun 27, 2001 12:25 PM
Conv389drv
Aftermarket Product Review
Dec 12, 2000 12:46 AM
