superam on or off?
Old Aug 29, 2004 | 10:14 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
superam on or off?
I have a superam,. On the first motor i did, i installed the longblock without the intake on. It was a royal PITA to install the superam in the car.. Can i install it on the motor and then install it in the car? will it clear going in? do i have to take apart the front end?
Old Aug 30, 2004 | 11:57 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I think you need to take it off (I did on mine)
What are you going to lift from and still clear that huge plenum if it's on the block when you cherry pick the motor?
Old Aug 30, 2004 | 12:09 PM
Car: 1987 GTA
good question, that's why I was asking if anyone had suggestions or if it was possible. -thanks
Old Aug 31, 2004 | 01:45 AM
BrandenCali's Avatar
I have a Sr on my ride now.. and The Sr is going to be on the motor when it goes back in.. Every thing should clear the front easily no brackets on front of course also.. smog pump etc..
Old Aug 31, 2004 | 09:30 AM
Car: 1987 GTA
thanks...i have no accessories hooked up,..fans are out, radiator out,...., so you think it'll sqweez in huh?
Old Aug 31, 2004 | 09:40 AM
vernw's Avatar
You'll have to use an engine hoist bar that's at least as long as the block is so the chains don't contact the SR or it will bend or break (it's only aluminum, i.e., soft metal). The SR will not like hoist chains pressing on it - which means you won't either if you ever want it to seal w/o a vacuum leak.
Just my two cents.....
- Vern
Old Aug 31, 2004 | 10:38 AM
Car: 1987 GTA
makes sense...worth doing. -JJM
Old Aug 31, 2004 | 11:10 AM
Yes, you will need to set up the hoist properly.. I am not putting the engine in myself someone else is.. So you will need every thing set up properly.. That I can't describe how it is done but, I do know it is possible and most likely less work that installing a SR in the vehicle..
Old Aug 31, 2004 | 11:24 AM
vernw's Avatar
You can probably put the runners on, but I wouldn't tighten them down until the plenum bolts are at least started. The lower middle runner bolts are a B*TCH, probably have to remove a couple or rockers to get to the (I did)
Old Aug 31, 2004 | 11:54 AM
Car: 1987 GTA
but much easier out of the car.!
Old Aug 31, 2004 | 04:21 PM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
Yep, I removed a total of 8 rocker arms to install the super ram. It's no big deal once you have the rocker arms out of the way.
Old Aug 31, 2004 | 04:26 PM
Car: 1987 GTA
the heads aren't assembled yet,..i'll have to assemble them, then take off the rocker.lol. what a waste. lol
martyr
Oct 13, 2010 09:20 PM
9D1Formula350
Mar 18, 2005 03:50 PM
Justin 87 GTA
Nov 8, 2001 12:25 AM
Blown GTA
Dec 8, 2000 09:57 PM
