Salvation has come for the tired LG4
Old Sep 8, 2004 | 07:14 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
monday we pulled her out w/ well over 190k on the clock.
Old Sep 8, 2004 | 07:33 PM
Tobias05's Avatar
rather barren... next pic is of the engine bay...
Old Sep 8, 2004 | 07:44 PM
Tobias05's Avatar
...:lala:
Old Sep 8, 2004 | 07:47 PM
Tobias05's Avatar
my new water pump, turned the CC dizzy into a primer, and the holley that needs rebuilt... slowly but surely.
Old Sep 8, 2004 | 09:57 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
good luck, i like the valve covers too.
Old Sep 9, 2004 | 07:07 AM
Cliff92Z's Avatar
Car: 1992 Z28
I remember the days when I had a LG4. Glad it's over.
Old Sep 9, 2004 | 08:47 AM
Tobias05's Avatar
yah the LG4 kept me happy for a lil while.... can't wait to get the 350HO in its place.
....I've unbolted the 700 from the Lg4, does it just slip off? The torque converter bolts are undone from the flexplate.
Figured I'd ask before i broke it
Old Sep 9, 2004 | 11:06 AM
Drakar's Avatar
Your tranny should just slide apart from the engine, same for the torque converter, as long as the bell housing bolts are out (6 of them) and the torque converter bolts from the flexplate (3?)
Nice engine, My LG4 has the same place your most likely does (floor/engine stand in a corner )
Old Sep 9, 2004 | 01:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think I can tell from the pic of the new engine, but please verify once & for all (to settle a discussion on another thread) if the Vortec heads have the "7th" exhaust manifold bolt hole. As in two bolt holes behind the rear port on the passenger side head.
Old Sep 9, 2004 | 02:29 PM
Tobias05's Avatar
there are only 6 bolt holes
Old Sep 10, 2004 | 09:06 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
wow is that ever nice,are ya putting headers on it too?
Old Sep 11, 2004 | 01:12 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
He better be! *shaking fist*
Old Sep 11, 2004 | 09:41 PM
Tobias05's Avatar
hedman long tubes! haha....
not gonna waste 3500 and run it through 1 inch manifolds....
Old Sep 13, 2004 | 08:41 AM
Tobias05's Avatar
SHE'S IN!
got the 350HO in last night w/ the MD8 attached.
Rebuilt the 4160, hooked up fuel lines, headers, spark plugs/wires, Starter, you name it.
The dizzy needs some work... cap/rotor/coil...
Now I gotta go through all the wires to sort out which ones i don't need....
I still have the hook up the rest of the tranny, driveshaft, and torque arm, hopefully this weekend I can get it back on the road.
I'm at school, I'll try to get a pic or two later tonight....
Man, not driving my car for two weeks sucks.
:hail: 350
Old Sep 13, 2004 | 10:36 AM
Car: 1983 Z28
Engine: 383
AAAAh there nothing like the smell of bf goodrich in the mornin
Old Sep 14, 2004 | 03:19 PM
Tobias05's Avatar
....:lala:
Old Sep 14, 2004 | 03:31 PM
Tobias05's Avatar
... i still have all my brackets, but which ones go to the power steering pump? lil lost there...
now to sort through the wiring, any advice? I only need the starter wires, sensor wires, and a tach and battery wires to the dizzy? Don't forget the grounds. Is that it?
TC lockup? I've searched that I can rig up a switch correct? In case i can't get that working right away, I have a 24,000 lb tranny cooler in my garage I'm gonna use.
Just ordered my dizzy tuneup kit, and throttle brackets...
I don't have a soccer game tomorrow, maybe i'll get it running.
... I'll make sure i run open headers the first day i can drive it to school again...
Brandon
Old Sep 25, 2004 | 09:16 PM
Tobias05's Avatar
350HO UP AND RUNNING!!!!
haha.... we got her fired up today
:hail: sounds super sweet w/ the open headers:hail:
timing is right under 8 degrees on the balancer and the holley is almost dead on tune too, fires up on the first crank of the key...
sort out the shift linkage and the tv cable and she'll be on the road...:lala: :lala: :lala:
finally,
brandon
Old Sep 26, 2004 | 12:57 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
my 350HO liked alittle more timing out of the box.
Just set your intial timing to what ever it needs to be at to get your total timing to around 32*
InfernalVortex
Apr 20, 2021 11:31 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
