need some opinions
Old Sep 13, 2004 | 08:58 AM
TheNewGuy1's Avatar
Car: 1986 Trans Am TPI
Engine: 305 v8
need some opinions
ok heres the deal..i recently got my 86 trans am...it was a steal for $500 and everything is mint on it..except the engine which needs minor work..anyhow..i wanna pull out the 305 and put something larger in it...my question is could some ppl give me opinions on which engine to swap it with...i really want a 400..but its hard to find one so im not sure..plz give some thoughs on what would be a good engine to put in..thanx
Old Sep 13, 2004 | 09:00 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
look around and find a good 350 and go with that
the 400 is getting harder to find which is why i would go with a 350 . they are everywhere and will be for quite some time
Old Sep 13, 2004 | 09:03 AM
TheNewGuy1's Avatar
Engine: 305 v8
just curious..the 350 would be an easy swap right? since its already got a small block chevy in it....
Old Sep 13, 2004 | 09:08 AM
THEGENERAL's Avatar
yes it would be a drop in .
are you going to use fuel injection or carb ?
Old Sep 13, 2004 | 09:14 AM
TheNewGuy1's Avatar
Engine: 305 v8
not sure..most likely fuel injected..i dont suppose the TPI off the 305 would fit the 350 would it?
Old Sep 13, 2004 | 09:21 AM
THEGENERAL's Avatar
yes the tpi will bolt right up but i believe your going to need some chip work in the computer and a few other modifications will be needed but it will work just fine
Old Sep 13, 2004 | 09:24 AM
TheNewGuy1's Avatar
Engine: 305 v8
what about the 383 strocker???
Old Sep 13, 2004 | 09:33 AM
THEGENERAL's Avatar
yes the 383 stroker is a very nice engine indeed depending upon what your goals are . horsepower and torque wise this can be a very good strong running engine
Old Sep 13, 2004 | 09:37 AM
TheNewGuy1's Avatar
Engine: 305 v8
yes HP and torue are my goals...i dont just want my TA to live..i want it to be beast...
Old Sep 13, 2004 | 09:45 AM
THEGENERAL's Avatar
well then id go with a good strong 383 stroker some good headers freeflowing exhaust atleast 3" pipe ,subframe connectors, and maybe a rear gear swap
Old Sep 13, 2004 | 09:52 AM
TheNewGuy1's Avatar
Engine: 305 v8
hmm..sounds good to me..thanx alot..maybe ill give my friends fbird a run for his money(hes got the big 455 eng.)..thanx again..oh..any suggestions on trans?..i mean i dont think i wanna keep the stock one on there..
Old Sep 13, 2004 | 10:06 AM
THEGENERAL's Avatar
depends on what you want there again there are alot of guys here that are running a th350 instead of the 700r4 .
if it were me i would use the th350 but you wont have overdrive with the th350 but thats a decision you will have to make
Old Sep 13, 2004 | 10:18 AM
TheNewGuy1's Avatar
Engine: 305 v8
hmm..ill have to look into it more..thanx again...
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
