need help ls1 just installed bogging down
Old Sep 27, 2004 | 02:18 AM
silverta8702's Avatar
i just finished my 02 ls1 in my 87 ta ,i have it running great at idle and revs right up but i went to drive it and under load it boggs right down and almost stalls , so far i dont have any ls1 edit stuff or my o2 sensors in ,thinking that might be it but maybe im missing somthing , and i was wondering what they were using for the cooling system , so far i dont have an overflow and have the vent tube from the ls1 going into the radiator .
Old Sep 27, 2004 | 04:18 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
sounds like a definite fuel starvation problem there, whats your fuel system like?
Old Sep 27, 2004 | 04:46 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
well, if he doesn't have the correct info in the ECM, then that would mean a messed up fuel curve...i think that issue along with the O2 sensor issue definitely needs to be addressed before you can accurately diagnose the drivability issue...
Josh
Old Sep 27, 2004 | 12:12 PM
1BadThirdgen's Avatar
Car: Trans Am
you MIGHT want to put the 02 sensors in.....
It's bogging down because of a fuel problem, probably too much fuel, and what controls the fuel mixture....
Yup, it's the 02 sensors you didn't install......
Old Sep 28, 2004 | 09:36 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Nah, I drove mine down the road with out any O2 hooked up nor the IAC and open headers, it ran fine. I'm sure not perfect, but it did not stumble, even at WOT so...
What does your fuel system consist of? And have you checked the PSI? It should be @ 58PSI. I'm running a New TPI pump with the 99 Vette Regulator/Filter assembly and have had no problems thus far.
Let us know.
Old Sep 29, 2004 | 04:43 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Yeah, I would have to say he is trying to run it with a stock fuel pump without a fuel pressure regulator. If you do have a redulator you should check if its set to 58psi indeed. Thats what that sounds like to me.
Old Sep 29, 2004 | 11:53 PM
CobraKilla92Z's Avatar
Transmission: M6
02 Sensors...After finishing up the cam on my friends 2002 Z06 our 02 sensor took a ****..The car barely will run and acts just like you're describing...Replaced the 02's and the car ran fine, tuned it to 433rwhp and 402flbs.
Infested
May 22, 2018 11:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Logan Bryant
Aug 27, 2015 11:52 AM
crazynights
Aug 21, 2015 06:53 AM
