at risk of being laughed out of TGO
Old Nov 1, 2004 | 05:07 PM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
I can already hear "get a 350" and "do it yourself"
http://advance-auto1932quality.cross...toreid=2370190
No price is listed
But do you think it'd be a good swap for lazy people?
Old Nov 1, 2004 | 05:16 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Might be, might not be... they are pretty vauge about what parts they used. If its built with quality parts and the machinework is good, then its prolly good.
Old Nov 1, 2004 | 05:33 PM
ljnowell's Avatar
I didnt see the specs to see what size engine, etc. But, if you are going to take one out and put one in, why note a 350?
Old Nov 1, 2004 | 05:37 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I used to work at Grand auto and all the engines that you can order from a regular old parts store are crap.I'm sure there are a few out there that are ok but if I were you and just wanted a replacement engine I would go through like gm goodwrench.
Old Nov 1, 2004 | 09:28 PM
Drakar's Avatar
ya if your looking for just a bottom of the line replacment engine, get the goodwrench one, comes with a warranty. that you know is good.
Old Nov 2, 2004 | 04:19 PM
ponykiller's Avatar
Engine: lo3
I'm trying to think cheap.( I know you get what you pay for).
Im looking for a drop and go replacment.I figured another L03 would drop in with little fuss(not changing ecm etc.).Also,someone told me Advanced would accept my old L03 as a core as long as I get the same thing.
AnywayI'd much prefer a 350 crate of some sort.But an impending divorce limits my funds at this point.
As far 350 go,Goodwrench has this http://www.sdpc2000.com/catalog/123/...ate-Engine.htm
Could I keep my TBI ?Could I transfer my current 305 mods(intake,cam) ?If I could do this and only rechip the ecm I may get it.
Old Nov 2, 2004 | 05:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Should work as described.
Old Nov 2, 2004 | 06:59 PM
ponykiller's Avatar
Engine: lo3
Meaning my I can get the Caprice 350,throw on my TBI intake,swap in my cam,add a 350 chip and be ready to rock?
Old Nov 2, 2004 | 10:51 PM
chevydude350ho's Avatar
Car: 90 Iroc-Z
Engine: carb'd 350
Transmission: built 700r4/3000 stall
Why not get this engine:
http://www.jegs.com/cgi-bin/ncommerc...71&prmenbr=361
Only mod you'd have to make to get it to bolt in is elongate the center 4 intake bolt holes to bolt the intake to the heads (takes 30min and a file).
Old Nov 2, 2004 | 10:53 PM
Car: 90 Iroc-Z
Engine: carb'd 350
The engine will run fine with 305 ecm, and 305 injectors. It will just run quite lean at WOT and have a lot less power than it should.
Old Nov 2, 2004 | 11:24 PM
five7kid's Avatar
The Caprice crate is a better choice than the Goodwrench 350. Not only are the intake manifold bolts at a different angle, the flexplate is different. The Caprice crate has a roller cam. The Caprice crate has center bolt valve covers. The Caprice crate comes with the harmonic damper. (I believe the Caprice crate also has PM rods.) Add it all up, the lower price of the Goodwrench crate ends up costing just as much, and you have a lesser product.
The 350 TBI swap is discussed often on the TBI board. Using the 350 TBI supporting cast is highly recommended.
Old Nov 2, 2004 | 11:34 PM
Car: 90 Iroc-Z
Engine: carb'd 350
Ah, forgot that it was a roller cam block, that would make it worth the money in itself. Afriend of mine got a replacement motor for his '90 Sierra locally. It was a roller block but they put in a flat tappet cam. And then at 20k all of a sudden he lost oil pressure since the place messed up the main bearings, and when he called for warranty the place is out of business. I wouldn't trust a locally built "replacement" motor, but you know the goodwrench one will be good.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
Johnny*G
Oct 20, 2015 12:37 PM
TheExaminer
Sep 28, 2015 02:28 PM
Linson
Sep 21, 2015 01:08 PM
