In the mist of taking the front end off, I forgot where a fricken vacuum hose goes...
Old Nov 9, 2004 | 02:44 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I was doing some fixes to a few places I put in the queue and finally got around to and I can't seem to find a spot for the vacuum hose that comes off near the coil (its wrapped in wire loom). It has a hose clamp on it too. Anyone recall where this goes?
Old Nov 12, 2004 | 02:10 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Ba-Da-Bump... I'd like to know this as well, I have the same problem...
Old Nov 12, 2004 | 09:27 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
back of the plenum, driver side? on my 91 Z, there are 2 lines coming from there - the one that goes to the plenum (has an L-shaped connector, no clamp) and a long line that goes up to the heater control valve.
Old Nov 13, 2004 | 02:08 AM
pasky's Avatar
Found it, was the 2nd opti vacuum line, I forgot the optispark has two vacuum lines. Thanks for the help.
Old Nov 14, 2004 | 12:45 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
did the car start w/the line unhooked?
Old Nov 14, 2004 | 02:48 PM
pasky's Avatar
yep, it would stumble when starting up but I guess the IAC compensated for it. Its running real good now except for this massive vibration I can't find. Im thinking its the dampener.
Old Nov 15, 2004 | 05:38 PM
z91bowtie1's Avatar
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
pasky got a question for you. there are two plastic vacume lines that come out of the fire wall on passenger side with some wire near heater hoses. do you know where to connected theses lines?
Old Nov 15, 2004 | 05:45 PM
z91bowtie1's Avatar
Engine: 96 LT1 5.7
here is a pic the two over the heater hoses.
Attached Thumbnails In the mist of taking the front end off, I forgot where a fricken vacuum hose goes...-heater-hose-fire-wall.jpg
Old Nov 15, 2004 | 06:39 PM
pasky's Avatar
Heya bowtie, I sent you a PM on how you did your heater hose, had a question about that if you could reply please. As far as those vacuum lines. I believe I plugged one up with a vacuum cap and put another on the passenger side intake vacuum port.
Old Nov 18, 2004 | 12:50 PM
pasky's Avatar
Z91:
Ok, just hooked up my heater last night (good *** it still works great). I looked at those two vacuum hoses you pointed out and what I did was buy 1 ft of soft vacuum line and a t-valve, I already had a vacuum hose from the LT1 wiring harness hooked to the intake so I hooked both that one that goes to the heater vent (its one of the ones you posted) and the one on the lt1 harness and plugged it into the t-valve and had the valve plugged into the lt1 intake. So both got vacuum from it. The other line (which goes to the black plastic heater valve near the passenger side manifolds/headers) I just capped off with a vacuum cap at autzone I bought for like a buck. You need one of those vacuum lines plugged in, in order to have your vents inside the car working, otherwise all you will get is defrost. Hope this helps.
Old Nov 19, 2004 | 07:14 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
I second that, I drove around a lil w/o it after my engine swap...
...kinda cold
Old Nov 22, 2004 | 07:16 PM
z91bowtie1's Avatar
Engine: 96 LT1 5.7
thanks pasky. hooked the lines up and works like a champ. i was getting a hhsss sound when i turned the heat on. it was driveing me crazy. ok now i bought a laptop so i can program the pcm. can you still hook me up with the program i need? and where can i find the cable? thanks again. just curious did you find out about that other vacume line you asked about? i'm woundering if i missed that to. i just can't place it.
Old Nov 22, 2004 | 07:31 PM
pasky's Avatar
sure thing, PM me your e-maill address. Give Dale a pm, I told him where to buy the cable but I lost the site, he will probably still have it. As far as the vacuum, it was an extra hose going to the opti. I forgot the opti had 2 hoses.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
