305 tpi to 350 tpi Questions
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Hey guys
I've done a few searches and i still have a couple of questions.
I have a 85 305 TPI that i want to replace with a 350
How much would it usually cost to buy an average rebuilt 350 and a pair of decent heads and put the tpi from my 305 on it?
It would have a pre 86 block because of the bolt patern right? Doesn't that make it cheaper?
Since I dont have a garage I would have a shop do it for me. They charge 60 dollars an hour of labor. How many hours does it take to do the swap?
I hear i need bigger injectors...what size/number?
What other part will i need?
I'm thinking my budget is around $2000
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: 305 tpi to 350 tpi Questions
thats not counting the price for a shop to install it ...
you really need to either get a bigger budget or just mod the heck out of your existing engine ...
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Re: Re: 305 tpi to 350 tpi Questions
Originally posted by THEGENERAL
the $2000 will barely get you the engine and a good set of heads and other parts required for the swap to use the tpi ....
Car: 1989 iroc-z camaro auto
Engine: stock 5.0 TPI
Transmission: auto
hey moreyes
hey wussup i was thinking about doing the same thing heres my aim sn if u wanna talk sometime im ony fifteen so i could learn some tuff from u to adn would really appreciate it thanks
Transmission: 4L80E/4L80E
Consider a 350 shortblock. Have your 305 heads rebuilt, with 1.94" intake valves installed and new valve springs and retainers, and if the machine shop doesn't charge too much, have them "pocket port" (also sometimes called "bowl work") the heads.
Most machine shops will have builder 350 shortblocks available. However, most shops that can do the above won't actually do the engine install for you. So, that could be an issue.
If all you want is an engine that works at least as well as your 305 once did, the Goodwrench 350 (such as http://www.sdpc2000.com/catalog/130/...ate-Engine.htm ) could probably be done for $2000 installed.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree with five. There is no point in re-building a 305 when putting together a 350 will make more power and in most cases cost you less.
Sanjay
Aug 12, 2015 03:41 PM
