engine swap what to do with the wires and lines
Old Nov 21, 2004 | 11:59 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
just pulled the l69 out and now im putting a 350 carbed mtr in. this carb mtr doesnt have any of the smog stuff on it. or 1/4 of the vacum lines and wires. most of the lines went with the engine but what about the wires. will my car still function without these wires. should i just leave the wires around the engine and only plug the wires that i need to it. also which wires do i need to hookup obviously the hei wire the starter wire alt wire. but what else.
Old Nov 22, 2004 | 10:06 AM
kevinc's Avatar
Car: 1982 Z28
Re: engine swap what to do with the wires and lines
You'd want to scrounge wiring diagrams for two connectors:
1.) C100: located on the firewall, drivers side, near the brake booster. Big plastic 2-piece rectangular block...small block is for your lights and signals, big block is for your engine/wipers/12VDC.
2.) C207: located inside the car, passenger side footwell, white/clear plastic 2-row connector.
Since you were carbed before, you're just concerned about getting 12VDC from the battery to the right places and getting gauge readings (oil pressure, coolant temp...).
Assuming your car is an auto trans, you also need to work up a way to manage the torque converter lockup.
Helms manual will run you around $80 or so from Dal at Vandevere Olds, and it will have everything you need for the diagrams.
Or...you can try alldata.com as they may have the same diagrams for less $$.
Old Nov 22, 2004 | 06:17 PM
jocww's Avatar
no its a t5 where do the idiot lights go to again and the lights are connected to the engine how.
Old Nov 22, 2004 | 06:31 PM
kevinc's Avatar
Car: 1982 Z28
I'll summarize my post above, since you didn't get it first time around:
Either buy a Helms manual, or get on alldata.com and buy wiring diagrams.
Old Nov 23, 2004 | 09:52 AM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
while doing my engine swap to a 350 carb. we ended up wraping up all the extra wires and throwin in them inside the right side fender where they can't be seen but still be accessed if i ever needed them (dont know why i would, just like to be careful)
we determined what we needed and didnt need by reading the car's manuals, go down to the store and buy the book for it, it has all the wiring diagrams in it... also, read online, i am sure you can find a place that will tell you wire by wire what you need, others have done this and i am sure documented it
Old Nov 23, 2004 | 01:52 PM
stenseltizm's Avatar
Car: 89 RS
Engine: 400 sb
i personally would do what Juan did. I am in the process of just finishing up my wiring harness. I eliminated any extra wires that were for the ecu and unrelated to a carbed engine or gauges. It was not worth the trouble. of course i didn't have accurate schematics either. It took alot of tracing wires. If you have an accurate schematic though, it might be fairly simple.
Edit: I guess this all depends on if your harness is one or two piece. if it's two piece, just unplug the harness coming out of the passenger side, you shouldn't need it, and can replace it if you ever do. if it's the one piece like mine, i'd just hide the unnecessary wires. though mine does look pretty clean now.
Old Nov 23, 2004 | 04:06 PM
jocww's Avatar
i believe mine is 1 piece as its a 84 and urs is fi so and is 2 piece so that would make mine 1 i should onlyneed the starter wires the hei wires and the alt wires to make the engine run correct. also i would only need oil pressure and then volts and water and that should be all correct.
Old Nov 24, 2004 | 03:28 PM
kevinc's Avatar
Car: 1982 Z28
You also need to bring fused 12VDC from the battery to the passenger compartment. Two separate full-time feeds if I recall right, one for the fuse panel and one for the headlights/signals.
Most thirdgens I've seen hang a few fusible links on the big battery positive pole of the starter.
Old Nov 24, 2004 | 04:34 PM
jocww's Avatar
kevin how were teh routed before. could i just plug it intoo what ever it was connected to be4
Old Nov 24, 2004 | 09:16 PM
kevinc's Avatar
Car: 1982 Z28
Mine's an '82 Cross Fire Injection chassis harness, not likely the same pinouts as yours, so I can't accurately tell you what to plug where.
Old Nov 24, 2004 | 10:08 PM
jocww's Avatar
i c thanks for the input now i just gotta get it all setup
Old Dec 8, 2004 | 09:06 PM
jocww's Avatar
sweet just got my parts in gonna do all this stuff friday
Old Dec 8, 2004 | 09:20 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Mine was easy. Disconnect it at the computer harness. There should be 2 plugs. One for all the ECM stuff (runs through pass side fender), and the other is the power for the ECM.
I removed the entire ECM harness and the plugs you need are still left. And unplug the "check engine" light.
Old Dec 12, 2004 | 01:33 AM
jocww's Avatar
what does the ecm look like and what plugs am i taking off also which one is the mil light. also how did u wire up your fans mine are elelctric, also i didnt see a water temp guage wire either nor did i see one for oil press.
Old Dec 12, 2004 | 02:46 AM
jocww's Avatar
also should i drop the engine tranny at the same time or do it sepratley like clutch and bellhousing and then mate it to the tranny once its in the car.
Old Dec 12, 2004 | 07:22 PM
jocww's Avatar
what did u guys use to pull out the front shaft bearing the one thats in the crank it wont come out and none of my pulley pullers will fit inside the whole
Old Dec 17, 2004 | 01:00 AM
Confuzed1's Avatar
Car: 83Z28 HO
It's a silver box behind the pass side kick panel. Two plugs go into it. One's basically a feed to the ECM from the fusebox. Just unplug that one and take the check engine bulb out. The big connector goes to the engine. Follow it through the passenger's side inner fenderwell. Disconnect/unplug what comes from THAT HARNESS ONLY. You'll figure out the rest.
I assume by asking that, you reside in a non-emissions area?
I know my fan isn't controlled by the ECM at all. Mine's electric too.
Just a temp switch screwed in the side of the block, and a relay for the fan. I have an adjustable now. Water temp gage wire goes to a sensor in the DS head. I don't know what a "mil" light is....
A Hayne's manual is invaluable....not trying to be a smart*ss, it's helped me. I have one! Sounds like you need to get the right color wires goin to the right places.
Oh, and you already know you'll need to get a vacuum advance distributor and non CC carb right?
Old Dec 17, 2004 | 04:38 PM
jocww's Avatar
mil = malfunction indicator light aka check engine light.
Old Dec 17, 2004 | 09:39 PM
jocww's Avatar
can i make my hei a vacum advanced unit i wasnt even paying attention
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
