motor and trans removal
Old Dec 22, 2004 | 06:15 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
i have basically everything off of my engine so far, the mounts are unbolted and im pretty sure all i have left is the trans, should i just keep a jck under the tranny and unbolt the crossmember and trans mount and it will just drop down?also where is the VSS attached, can i remove this when it is unbolted and dropped down? or is there not enough room? i have the car up on jack stands in the back, (about 12 inches) and the fron up on the standard ramps (however high they go) would i need to get it higher to be able to hoist the motor and trans out? thanks for everything this swap is hard enough out in the cold, the last thing i need to do is screw this up..... alll help is really appreciated..... -thanks, ill also try to get some pictures today while i attemp to remove the engine
Old Dec 22, 2004 | 01:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The VSS (if electronic, which I believe a '91 would be - just don't know from personal experience) is located on the transmission tailshaft housing just like a mechanical speedo cable would be. All you should have to do is unplug the harness.
The jack under the pan is a good idea. That's the way I go about it, except this time I plan on using the tranny cradle jack I have now which I didn't last time. That doesn't require the 2x4 under the pan, and rolls more easily with the eng/tranny movement.
A tilt sling is a good idea, if you hadn't already made provision for that.
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 13, 2015 12:59 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
Leggman1
Aug 6, 2015 04:15 AM
