T5 on a LS1?
Car: 1989 iroc
Axle/Gears: 2.77
T5 on a LS1?
Can a t-5wc bolt up to a LS1? I know how much better a t56 is etc. Starting a ls1 swap and looking to use what I have until purchase of t56. If you are going to answer buy a t56 dude, don't bother just want to know if this is doable. thanks
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
T5's don't really stand a chance on a built 350. Don't expect any better on an LS1.
But I would imagine the swap could go either way.
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
It will, but you need the v8 bellhousing and one bolt hole isn't going to have a bolt through it, but it from what i've heard, its still stable.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The flywheel will fit ON the back of the crank... clutch arrangement / depth on the pilot shaft maybe of concern....
Car: 93 240SX
Engine: LQ9
Originally posted by ljnowell
Thats kind of what I was wanting to know. I figured it may have been something like that. You would think though, that if the 700r4 would bolt up, the manual would too.
Im pretty sure the clutch depth would be the same because you can shove a lt1 t-56 on a LS1 no problem except the bolt hole as mentioned above. Believe it should have the same travel.
