swapping 2.8 2bbl to 2.8 MPI
Old Dec 30, 2004 | 08:09 PM
slow83sc's Avatar
Car: 83 camaro sport coupe/ 1981 Camaro
Engine: 2.8 2bbl
Transmission: thm200c
I just aquired a 89 rs with the 2.8 MPI.
The body on the car is completely shot, but the engine and trans is as close to new as I've seen, like they were changed not too long ago.
I'm going to install the engine and trans in my 83, what kind of pitfalls do I have to look forward to during the swap?
It seems easy, I'm just wondering if anybody has done this kind of swap in the past, and could pass along some pointers.
Will all of my existing dash electronics plug into this setup, or, do I have to change every single wire?
The setup uses mass-air if anybody is wondering.
Old Dec 30, 2004 | 09:08 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Well if the carbed engine had a mechanical engine mounted fuel pump you will have to swap in the electric in tank fuel pump (I don't know if the tank is different) and lines, wiring, relays, harness and ECM.
Best bet is to park both cars side by side, label everything and take your time.
Old Dec 30, 2004 | 10:13 PM
slow83sc's Avatar
Engine: 2.8 2bbl
Thats pretty much what I thought too
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
86Base
Aug 8, 2015 01:34 PM
