engine change
engine change
I have a 85 T/A with 305TPI and am changing to a 350 with the same TPI setup. My question is what changes have to be made to the ECM, sensors, etc....... any help would be greatly appreciated this site has helped me with lots of different issues. Thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome abaord!
The
is your friend. This site has a bajillion threads concerening your topic at hand. You will find your info with a few minutes of searching.
The
is your friend. This site has a bajillion threads concerening your topic at hand. You will find your info with a few minutes of searching. Thanks I see lots of good info, just one other thing i am getting conflicting info on are the 350 TPI heads any different from regular 350 heads on a pre 87 vintage engine. Thanks
Car: '90 RS
Engine: 377 LSX
Transmission: 4L80E/4L80E
Shifty, his TPI is an '85 version. So, it won't have the 72 degree bolt angle on the center two base bolts.
To be honest with you, I don't know what the pre-'87 "good" casting numbers are. However, the 113 aluminum Vette/ZZ4 heads would bolt right to that base.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
