fuel block off plate
Old Jan 8, 2005 | 11:43 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
i have the blue gasket for the fuel block off plate, but do you use silicon on it too black rtv?
-also, is there a specific patternt that you bolt on aluminum 350 heads..i know you have to finger tight, then torque in about 10 incrimetns till you get to 65 lbs.....let me know. thanks
Old Jan 8, 2005 | 12:11 PM
ljnowell's Avatar
Re: fuel block off plate
The heads must be torqued in sequence, if you expect them to not blow head gaskets. www.nastyz28.com and www.mortec.com both used to have specs for this, and so do the chiltons manuals. Follow it, if you want it to last. You only need to 3 step it. I usually do it 25lbs, 45lbs, 65lbs. I have done it in a two step also 35lbs, and then 65lbs, without issue.
Old Jan 8, 2005 | 01:35 PM
Car: 1987 GTA
thankyou. I appreciate it.. anybody know if you are supposed to use the ultra RTV on the fuel vlock off? thanks -
Old Jan 8, 2005 | 02:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
RTV works fine on that.
Old Jan 8, 2005 | 05:08 PM
Car: 1987 GTA
so you are supposed to? or just have the gasket dry?
Old Jan 8, 2005 | 05:34 PM
ljnowell's Avatar
Definately RTV it. It is a gasket item that provides oil retention, so better safe than sorry.
Old Jan 8, 2005 | 05:54 PM
Car: 1987 GTA
that's what i thought,,,,but i guess not much since you torque it down to like 25lbs or something. i don't want it all to squish out. I'll just put on a thin coat. thanks man
Old Jan 10, 2005 | 01:20 PM
Car: 1987 GTA
so, a thin bead? also,....I can't find the head torque pattern on those sites...anyone else know where to find it?
Old Jan 11, 2005 | 09:16 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I found this online:
http://www.boxwrench.net/specs/chevy_sb.htm
Old Jan 12, 2005 | 06:08 PM
Car: 1987 GTA
am i supposed to use RTV on the head gasket?
Old Jan 12, 2005 | 06:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No.
If you want to use a metalized paint such as aluminum or Copper Coat, that's okay. But, no RTV or other gasket sealer.
Old Jan 12, 2005 | 07:24 PM
Car: 1987 GTA
hmmn mettalic paint???? how about on the front seal? where it touches the timing cover
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
mhatfield 14
Oct 24, 2015 07:48 AM
1985chevydude
Aug 20, 2015 12:29 AM
