350 engine block
Old Jan 9, 2005 | 06:34 PM
thomas_iroc's Avatar
350 engine block
ok looking for an 350 engine block for my305 86 camaro,what do i need to know?do i need 2 peiserear seal or 1? wanna hook up to my brand new t5 transhave new 305 crank will that work for 350?need to help me before i buy something that i can not use.
Old Jan 9, 2005 | 06:38 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
you want a 2 piece rear seal, 305 crank wont work. is the t5 built to handle the torque the 350 puts out? gm didnt do that combo for a reason. its not always reliable but some people have had no problems with it.
Old Jan 9, 2005 | 06:56 PM
350 engine block
i just got the t5 it is the ho,and the 305 does make a lot hp but good tq i hope it will be ok
Old Jan 9, 2005 | 08:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It doesn't make any difference whether you get a 350 with 1- or 2-piece rear main seal. Just get the pieces you don't have to match whichever you get (assuming the '86 isn't what had the T-5).
The 305 crank you have is pretty much worthless. It could be made to work in a 350 with balancing, but by the time you get it balanced, you could have reworked or bought a new 350 crank.
Old Jan 15, 2005 | 02:05 AM
dusty89camaro's Avatar
Car: 91 Camaro RS
Did the 1989 350's come with a one piece or two piece rear seal?
Old Jan 16, 2005 | 02:21 AM
Night rider327's Avatar
Car: 1988 Camaro
86 or 87 was the start of the 1 pc rear main seals. (I get those 2 years mixed up all the time)
The T-5 will last longer than the car, if you baby it, but when you start adding more power, faster speeds, rough driving, power shifts, traction, etc it's life will end very quick.
The 305 HO's was really weak when you look at what you can build and how easy it is to get power out of a 350 engine
What was the 305 HO like 190 HP and 240 ft lbs?
If you rebuild a 350 your self with mild performance in mind then you could see numbers in the 320-400 HP with 350-450 ft lbs real easy.
Thats about double the power of a 305 HO..
As far as which to get, 1 pc or 2 pc main. Everybody has thier own opinions. I have mine.
I rebuild only 2 pc. rear seal engines for performance use. Not to mention theres alot more 1969-1985 or 86 350's in junkyards than they are 1986 or 87 up 350's
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
