Corv. alu heads with bowl job from SDPC
Old Mar 1, 2005 | 07:43 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
Seen in their catalog that they have the usual Corvette alu heads and some with bowl job.
Whats a bowl job and is it worth the extra $.
Do they fit a 305? (don't know if there's something different to a stock L98 alu head)
Pat
Old Mar 1, 2005 | 10:17 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I looked on their site real quick and didn't see such heads, but, to answer your questions:
A "bowl job" is porting/clean-up of the port area just under the head of the valves - the "valve bowls", if you will. Also known as "bowl work" and "pocket porting" (porting of the valve pockets, same as valve bowls). It smooths and blends the opening to the valve with the port to provide improved flow. This is generally where the most benefit from porting will come from.
Those heads will fit a 305, but they will lower the effective compression because of the aluminum material. They should make the engine run better, but if you have absolutely no plans beyond having these heads on a 305 (such as putting them on a 350 some day), they should be shaved to reduce the chambers by 4 to 6 cc. They also do not have the exhaust cross-over passages.
They are the same heads that the '86-1/2 - up Vette L98 used.
Old Mar 1, 2005 | 01:08 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
vette heads are 58cc same as a 305 heads. These heads are perfect for a 305
Daz
Old Mar 1, 2005 | 01:31 PM
five7kid's Avatar
58cc 305 heads are made from cast iron.
Cast iron L98 heads are 64cc. Aluminum L98 heads are 58cc. They do this because of the heat loss through the aluminum, which lowers power output. To regain the power, they raise the static compression ratio via smaller chambers.
If you use aluminum heads on a 305, you should raise the static compression by about half a point (9.5:1 to 10:1).
58cc aluminum heads are not perfect for a 305.
Old Mar 1, 2005 | 06:41 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
so what compression ratio do they raise to on a 355(.030 over bore) with flat top pistons(with 4 valve reliefs)?
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
You dont need to raise up the compression going to AL.THe flow characteristics, and bigger valves will overcome the THEORETICAL heat loss. If its a bolt on job it willl be good. Slap the heads and get a matching cam and you will see good gains. You would need to elongate the two middle bol t holes if you have an 86 or older intake.
Old Mar 1, 2005 | 07:06 PM
five7kid's Avatar
As I said, they should make the engine run better because of increased flow capacity. That still doesn't make them "perfect".
L98's were 9.3-9.5:1 with iron, 10:1 w/Al heads. What they would be on a rebuilt 350 would depend upon the piston pin height, relief volume, deck height, and gasket thickness/volume.
Old Mar 1, 2005 | 07:42 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
youre right about "perfect" I shouldve said"theyre a perfect bolt on"..Its a basic replacement job
Old Mar 2, 2005 | 12:46 AM
Car: '91 Z28
Engine: LB9
Ahh, sorry. they are in the printed catalog.
Thanks for the explanation!
Old Apr 18, 2005 | 07:50 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
Not sure they are a perfect fit. If the D-port are the same as the earlier non-D than they may not be. I fit a set of the early non-D on a 305+.030. When set on the engine and looking at the chamber from the bottom of the cylinder, I saw that the chamber overhung the side of the cylinder opening (exhaust side of head). Would seem to me that the major rush of incoming will slam the top of the block before entering down into the cylinder. I don't know if this is normal but I can't think it is this way with normal 305 heads (guess I could check sometime). Bought these heads to go on a 305 because I earlier found on TGO the same stuff mentioned here. I don't think the benefit will be noticed with the current situation and don't plan on putting them on the 305(310). Or could this actually be a benefit?!@?
Old Apr 19, 2005 | 02:16 AM
FastZ28*84's Avatar
Car: 84 Z28
Engine: 72 350 .030 over
Transmission: 89 WC T-5
When I had my original L69 305 I put the aluminum L98 heads on it and noticed it made the exhaust crackley, but I did pick up a little over 3 tenths of a second in the quarter mile. These were stock with no porting so you could see even more performance gains.
Old Apr 19, 2005 | 06:07 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
actually, i'm quite positive that all the aluminum heads got the same bolt pattern as the pre-86 iron heads and will not need modifications to such said intakes.
Old Apr 19, 2005 | 10:02 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
100% correct
gixxer92
Sep 1, 2015 04:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
