84 crate swap
Car: 84 Z28 Matrix 3 convertible
Transmission: 700
84 crate swap
I am getting ready for my first swap, and after searching I have a few questions. I have a 350 edelbrock crate motor and I am getting ready to put it into my 84 vert. The original motor is the 305HO, what wiring/computer issues will I have? I can't find much on 84 carbed wiring. Will I need a new fuel pump? Any other advice would be much appreciated.
Transmission: 700
It's all there, long story but ended up with a pickup with the motor that was a project. It was running fine but the truck is a pos so the engine is going in my car.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could just drop it right in with your computer controlled carb, distributor and sensors, if you wanted.
Engine: 383 Carb
Transmission: 4L60
You might lose a little power, but probably not that much after tuning. Your mileage would be better, and you wouldn't have to hack up your car to do it.
Transmission: 700
Engine: 383 Carb
Transmission: 4L60
If it's the Performer 2101 spreadbore intake you have, go ahead and leave it on, it'll fit your stock Q-jet just fine. It won't take your EGR valve though.
Transmission: 4L80E/4L80E
The carb and distributor are non-computerized, whereas your current carb and distributor will work fine with the engine (and fit the intake as Apeiron says). The manifold is non-EGR, so if you use the CC parts currently in the car, you'll need to keep the EGR solenoid there with no vacuum to it so the computer will stay happy. You may need to back the timing off a bit to avoid mid-throttle pinging (but, maybe not).
Using the carb and distributor currently on the engine will require some wiring harness changes (mostly removal). However, I'd say you'll get better power with the q-jet than you would with the Performer. And I'll 2nd the better mileage with the CC stuff than the Performer. And, with the Performer, you'll have to figure out some means of torque converter lock-up.
theshackle
Mar 5, 2017 06:37 PM
