buick roadmaster lt1
Old Mar 25, 2005 | 05:03 PM
91rs5.0's Avatar
Car: 91 RS (Black, T-top)
Engine: 5.0
Transmission: 5-speed
what are the differences in wiring for a buick roadmaster lt1 as opposed to z28/ta lt1s? will the 5 speed from my car bolt up to the lt1(for temporary use)? and does the oil pan need to be changed to fit the f-body? thanks.
Old Mar 25, 2005 | 05:29 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
cylinder heads..i dunno what else
Old Mar 26, 2005 | 06:45 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its basically the same engine, but has cast iron cylinder heads instead. The oil pan will fit.
Also note that although I never saw one in a Roadmaster, many Caprices had the L99 4.3 V8 which looks just like the LT1. So make sure its the 5.7 Liter.
Old Mar 26, 2005 | 06:51 AM
91rs5.0's Avatar
Engine: 5.0
yea i know about the heads. i just wanted to know if theres a difference in wiring, and if it will bolt on to a 5-speed.
Old Mar 26, 2005 | 07:14 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
standard in 94-96 Roadmaster
I haved two Roadmasters but not one has an LT1
Old Mar 26, 2005 | 08:49 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
The wiring is very similar only being different as far as accesory hook up....the accesories are located different on an f-body Lt1 as opposed to the b-body lt1 you have. I believe I posted up in the Lt1 wiring thread about connectors (can't remember for sure, it was a long time ago). It is basically the same motor as a 9C1 Caprice (Police Package), an Imapala SS (the real one from '94-'96 before Bob Lutz ruined that too ), and some Cadi's from that era (can't remember exactly which ones though. There may be more info on that particular configuration over at www.theherd.com
Old Mar 26, 2005 | 09:17 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
If it's not up there, let me know and I'll see what I can do.
Old Mar 26, 2005 | 10:26 AM
91rs5.0's Avatar
Engine: 5.0
thanks
Old Mar 26, 2005 | 02:16 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I'm using a roadmaster LT1. works great
Old Mar 26, 2005 | 02:51 PM
91rs5.0's Avatar
Engine: 5.0
will it bolt up to my t5?
Old Mar 26, 2005 | 09:35 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
good question. I never looked to see if the crank was bored for the pilot bushing. Chevrolet usually bores all their cranks but all these iron headed LT1's were put in front of automatics. That T5 probably won't hold up too long anyway.
Old Mar 27, 2005 | 07:12 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Tons of B-body enthusiasts are putting T-56's behind their LT1's, so I would imagine a T-5 will work just fine.
Old Mar 27, 2005 | 09:09 AM
91rs5.0's Avatar
Engine: 5.0
yea im not expecting it to hold for a long time, just enough time for me to find a good deal on a t56
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
Nick McCardle
Sep 10, 2015 08:36 PM
