Swapping L05 to 70's 350...?
Old Apr 28, 2005 | 02:04 AM
89 tbi bird's Avatar
Car: 89 FireChicken
Engine: TBI
Currently in the car is an L05 from a Chevy Suburban. According to various sources, it is low compression (8.3:1). Oil pressure is starting to drop when warm, but I have an opporotunity to aquire a 1970's 350 long block for free. I am pretty sure it has smogger 76cc heads, but my swirl ports 65cc (?) should be okay with it until I can afford better. The main advantage to this is, that I can rebuild the 70's block and still drive the car, until I am ready to swap. I was thinking about the Crane compu cam 2050 for flat tappet, and new bearings.
My Questions:
- Anybody have any ideas as to what i would be looking at compression-wise, and/or hp-wise?
- Is the 2pc main flywheel the same number of teeth as the 1pc (L05)?
- Any problems from doing this swap?
Old Apr 28, 2005 | 05:09 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
If the engine has flat top pistons, you should see an improvement in the CR range, probably around 1 full point. add in the compu cam, and you should be somewhere around 250ish hp, i figure. you'renot going to see a real difference unless you have already replaced the TBI exhaust. After you do a full 3" exhaust, you should be close to 280fwhp.
not a bad improvement from the 170fwhp 305 that came in the base model...
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
