2.8 carb to LG4 carb
Old May 12, 2005 | 08:04 PM
slow83sc's Avatar
Car: 83 camaro sport coupe/ 1981 Camaro
Engine: 2.8 2bbl
Transmission: thm200c
I'm swapping my engine from the 2.8 to the lg4 305, I'm going to swap the fuel lines over also, are they easy to change over, or will I have to drop my tank out to change them?
Old May 13, 2005 | 12:23 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
They are the same from the trans crossmember back. Measure twice and cut once. I used compression fittings when I did my 83, but a short length of rubber fuel line would work as well.
Old May 13, 2005 | 08:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Keep the V6 lines and splice lines to run across the front of the front crossmember. That's a cooler environment than what the factory did, running the lines over the transmission and next to the exhaust. Cheaper and easier, too.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
spartanreaper
Sep 25, 2015 07:22 PM
rjcme
Sep 5, 2015 01:23 PM
