1989 LQ9 swap
Old Jun 9, 2005 | 11:39 AM
Omega-Red's Avatar
1989 LQ9 swap
:: Project Information ::
Drivetrain
LQ9 engine swap (380HP close to 400 tq) twin T4
T56
12 bolt rear end
True dual Borla exhaust
Racing seats
8 or 10 bolt roll cage
Replaced gauges
Vinyl interior
Metal plated floors
Exterior
Fiberglass front end including front quarter panels hood and bumper
Fiberglass trunk lid
Fiberglass doors
Black paintjob
5 star deep dish chrome wheels
We started removing engine Monday June 6 2005
Here is pictures for the past 3 days we been trying to archive it. We went trough a lot of torture. Every single bolt in this car is giving us headache. Seems like a car doesn't want to give in too easy to this modification.
We didn't remove engine yet due to 1 bolt that is not removable. It is a bolt that is stuck between transmission and engine block. The thread is most likely gone and there is no way to grab a damn thing.
Camaro being taken out to fit engine hoist. On the left you can see LQ9 on engine stand.
This is the bolt that is giving us headache. It wont budge what so ever. We even tried heating it up and then trying to remove it but nothing happened
Is there any other way to remove the engine?
So far we removed everything that's holding transmission from the floor. We wanted to disconnect the driveshaft but at the front end it looks like it has no bolts. It looks like it was clipped.
Besides grinding off the bolt between tranny and engine block is there any other way to go around this to remove the engine?
Old Jun 9, 2005 | 01:05 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Driveshaft slips out of the tranny, you don't unbolt the front yolk.
Remove the shifter from the tranny. It looks like its a T5. Remove the 4 bolts holding the tranny to the bellhousing, slide tranny out
*or*
Just pull the motor straight up, angling the the whole thing to accomodate for the trans pointing down.
You're almost to the hard part, which is installing everything
good luck
-jason
Old Jun 9, 2005 | 01:12 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Pull the motor and tranny at the same time, makes it a whole bunch easier getting the new setup in the car. Just remember to drain the fluid out of the tranny or it will end up coming out the tailshaft where the driveshaft yoke slides in.
Old Jun 13, 2005 | 07:46 PM
Omega-Red's Avatar
We finally got it out.
2 things we had problem with. We didn't remove the headers. So after we did that we pulled engine a bit back in order for a driveshaft to slide out. Then we lifted the engine straight up. The bolt that was giving us hassle I torched it then hammered the socket in it and finally it came loose. All in all we did it in 3 hours. Now the long painful process of the project. Getting it all done!!!
Old Sep 20, 2005 | 11:54 AM
slick00m's Avatar
Car: 1989 Camaro IROC
Engine: 6.0 LQ9
Any new progress on this swap? I am about to start the same thing, 6.0 LQ9 into a 89 iroc. Any words of wisdom would be greatly appreciated.
Old Sep 20, 2005 | 12:06 PM
Omega-Red's Avatar
No progress as of yet. It's a financial struggle for us to save up for T56 12 bolt rear end and other little things. Car still standing in garage waiting for its moment.
Old Sep 20, 2005 | 12:11 PM
slick00m's Avatar
Engine: 6.0 LQ9
I understand, I'm doing the T-56 also and there a bit expensive. maybe i can find one at a junk yard. Do you have the engine in the car yet?
Ryan
Old Sep 20, 2005 | 12:37 PM
Omega-Red's Avatar
Ryan
No not yet. It's on the engine stand. We have to tow the car to the shop to weld in new floor panels and reinforce the body before doing anything. Then probably going to send it to body shop to get the interior paintjob done.
1984HO
Mar 19, 2021 11:59 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Roblyons
Sep 12, 2015 10:29 PM
Roblyons
Interior Parts Wanted
Aug 30, 2015 12:07 PM
kyleb24
Aug 15, 2015 08:24 AM
