Compatibility issues?
Old Jun 17, 2005 | 01:16 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
i revently wrekced my 87 355 5 speed formula. I am gettin a new body which is looking to be an 82-84 trans am 5 speed car. I wanna know what kinda compatibility issues i may run into while doing the swap. i know the engine will bolt up, but will there be any problem using my t-5 and my 10 bolt from the 87 or the hydraulics for the clutch? Pretty much is there ANY thing that will be different on the 83 then there was in the 87? thanx.
Old Jun 18, 2005 | 10:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The brake lines will be SAE instead of metric, the clutch will be mechanical instead of hydraulic.
I'm not completely sure about this, but you may have to drill the firewall to fit the '87 clutch master cylinder.
Otherwise, you'll probably come across some little things, but in general shouldn't be a big compatibility issue.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
