Harmonic Balancer installation
Old Jun 24, 2005 | 01:22 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I installed the damper on the car and noticed that there is a little over 1/4 inch gap from the damper to the timing cover seal. I installed the crank pulley and it lines up with the rest of the pulleys. Is it safe to leave it where it is at or should I keep pushing the damper until it is flush with the timing cover seal and use spacers?
Old Jun 24, 2005 | 02:08 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Do you mean the back of the damper wheel or the snout of the damper lacks 1/4"?If the back of the damper is 1/4" and your pulleys line up,you should be good to go.But if the snout 1/4" from the seal,you got something way messed up going on,and you absolutely should not continue until you find out what's up.
Old Jun 24, 2005 | 04:25 PM
86z/92rs's Avatar
Here is a picture of teh gap:
italiano67
Dec 11, 2016 09:21 AM
LT1Formula
Nov 16, 2015 01:13 PM
Linson
Aug 31, 2015 04:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
theshackle
Aug 22, 2015 06:52 PM
