heads and casting numbers
Old Jul 11, 2005 | 06:14 PM
philllk's Avatar
Car: 1986 trans am
Engine: 350 carburated
Transmission: 700 r4
What heads could I use on a 1992 block, people talk of 083"s
but what is the realcode numbers on them
Old Jul 11, 2005 | 06:47 PM
rsn932's Avatar
083 is the last three digits of the iron 350 TPI head casting number. All the numbers that come before the last three are useless for figuring out which head to use. You can really use any head you want on a 92 block....
Old Jul 11, 2005 | 07:40 PM
philllk's Avatar
Car: 1986 trans am
heads
as long it is 87 or newer right
Old Jul 12, 2005 | 05:48 PM
rsn932's Avatar
you can put on any head you want. older than 87 will need one style of intake bolt pattern, 87 and up will need the newer kind. you can get angled washers though. what kind of intake are you using?
Old Jul 16, 2005 | 05:55 PM
philllk's Avatar
Car: 1986 trans am
intake
ZZ4 intake
Old Jul 16, 2005 | 06:02 PM
rsn932's Avatar
well I don't know if the ZZ4 is the new or old style bolt pattern. Anyone know?
Old Jul 17, 2005 | 09:37 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A "ZZ4 intake has a conventional SBC intake bolt pattern and angle.
A 083 head that came form a L98 TPI motor will have the center two bolts at a different angle on each side. you can
elonggate the center bolt holes on a ZZ4 intake and use washers under the bolt heads.
Vortec heads require a "vortec intake"
Early pre 1968 heads don;t have the alternator bolt holes in the ends of the heads.
TBI swirl port heads are not worth using for performance.
LT1, LT4 heads will not work on a conventional SBC without mods to the water cooling holes on the decks.
Some of the 70's era smog heads are not worth using 882 624 993 etc.
A 305 head will bolt on but requires larger 350 sized valves to make decent power.
Old Jul 17, 2005 | 10:35 PM
philllk's Avatar
Car: 1986 trans am
Thats the info I was looking for, thanks
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
dcbsracing007
Aug 18, 2015 07:24 AM
