Anyone Ever Put A 500 Caddy In A Third Gen?
Old Jul 26, 2005 | 02:25 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
It was suggested in another thread,but I am just curious,has anyone here ever done it or seen it done?I know that they are low RPM pigs,but there's a little stuff out there for them,would be neat,hmmmmm.........
Old Jul 26, 2005 | 03:31 PM
runnriottt's Avatar
Car: 1991 RS
Engine: 7.4 454
Transmission: Th 400 man valve stage 3
boat anchor. and w i d e. very little to do with it, but i would imagine there is somebody, with enough money and time....
although i did see a hot rod top ten shootout with a fox body mustang sporting a 500. stock bottom end, huge bottle, and a quote from the driver on how cheap it was. to each there own i guess...
Old Jul 26, 2005 | 04:11 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Cadillac 500's are really good motors. There is even a great aftermarket for them now. The are far superior to the BBC because it is quite a bit lighter. There are several members on here that have the Cad 500 in their rides.
Do a
Old Jul 26, 2005 | 05:22 PM
runnriottt's Avatar
Car: 1991 RS
Engine: 7.4 454
hmmm... there is an aftermarket now.. wasent when i had my 500
that was 8 years ago... i wanted to stuff it in an jeep, back then there just wasnt enough to do to it, not that i could find, so now i do bbc's
i would love to see pics, and time slips.
now ill shut up and read some more.... lol
Old Jul 26, 2005 | 10:10 PM
Irockz's Avatar
It's just a notion I never could put out of my head.I have no plans to do it,but if I had the car,and an engine I knew ran good laying around,I'd damn sure see what happened.It would be fun to "old school" it.Fab up mounts,brackets,etc.Slip a mild cam into the stock engine,otherwise,just stick to the classic bolt-ons,intake,make up a set of headers,etc.You know,just a grassroots project for fun.I've read that you can bolt 472 heads on a 500,and crank the compression up to like 12:1,that's cheap power.
Anyways,anyone else got an opinion?I'd love to hear from anyone or see pics of the swap!Or from anyone else who's ever had this wierd yearning to do it!
Old Jul 26, 2005 | 11:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yeah, do a search. one of the threads has a link to a site where the guy cut the firewall to set the engine back some for better weight distribution/balance. crazy shizzz.
Old Jul 27, 2005 | 02:12 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Suppose, just for a minute, that there was an old 1973 Eldorado sitting out in a field....with a 500 sitting in it. Would you drive to NE Kansas to pick it up, Irockz?
Old Jul 27, 2005 | 09:25 PM
Irockz's Avatar
Well,it's quite possible I would.Anyone got a Hashed out third gen to peddle cheap or,free?
Old Jul 27, 2005 | 10:17 PM
runnriottt's Avatar
Car: 1991 RS
Engine: 7.4 454
well yes... yes i do.
pm me if your serious...
Old Aug 7, 2005 | 11:23 PM
Babemagnet's Avatar
Car: 1982 Trans Am spraybomb black w/flames
Engine: 305 edelbrock carb., intake, go fast chrome valve covers!
Transmission: TH350
Hey dudes-
Everything you ever wanted to know about caddy motors can be found here www.cowboyseven.us ,the guy w/ the cad powered mustang goes by LUXLX there, or here www.500cid.com for parts, swap ****, headders, cams ect. Also, do some looking around on that cowboyseven forum for a guy that goes by POTTER. Check out his website for ****in' radical cad motors.
By the way big caddys run real good, I have had a bunch. Anyone who tells you they suck is just being stupid. I'm going to put a 500 in my T/A, smoken' those BFG's baby!!! Stock 500 is 300hp 500lbft on the dyno, now all bull**** aside, thats alot of useable power no matter what brand the **** is.
Old Aug 10, 2005 | 07:36 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
(LT1Guy, on Redraif's logon)
Actually, it shouldn't be that bad of a swap. Its fairly light for an engine of its size once you dump the junk stock intake (probably the heaviest one you will ever encounter!), and unlike a BBC they are cheap and available. We have two of them; both came from Pull-A-Part for about $120 each, and one had freshly rebuilt heads! Most of them were rated at around 500/525 torque STOCK, and building one to make 600/600 or better isn't all that difficult, or as expensive as you would think. The blocks are VERY strong, the heads flow well (Magnante at Hot Rod claimed they flowed as well as old Mopar Max Wedge race heads) with even mild porting, and Bulldog is now making aluminum heads and single plane intakes for them. The cranks are very durable as well, and according to Maximum Torque Specialties the stock cast pistons will take a big nitrous hit...they have used up to 250hp worth on some of their land yacht test cars.
The motors only have two real weaknesses...the rockers ( a mickey mouse pedestal type that tend to break), which is easy enough to fix (max Torque has shaft rockers that won't break the bank); and the connecting rods, which don't like a lot (over 5500rpm) of revs. Of course, with 500cid, you don't exactly have to rev the snot out of it anyway! If you're so inclined, Eagle Olds rods can be used with a special piston (Ross) to eliminate the problem.
BTW neither of Redraif's motors are going in an F-body; one is going in her International Scout II, the other one (which has the shaft rockers, Eagle rods, Ross pistons, etc, and a few other goodies) is going in her Dually...its still at the machine shop. I'll likely be buying another to go in my 85 TA, just as a super cheap toy (lots of NOS).
BlueIroc-Z
Jun 9, 2019 03:22 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
LittleFranks
Aug 20, 2015 03:55 PM
sreZ28
Aug 14, 2015 07:48 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
