bbc mock up
Transmission: 4L80E/4L80E
Don't you hate doing that to headers?
I had to do the same thing to the #5 on the 396 in the '57. Seems to run okay in spite of it.
I have heard of several members using them, but had never seen a picture of #5. Had no idea they came like that.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd think there has to be a better way to do it, but I'm sure it would be more expensive to manufacture.
Car: 1989 Camaro RS
Engine: 396 BBC
Transmission: Turbo 400
Axle/Gears: Moser 9 inch/4.56 gears
Hey ckeene502, glad to see you're going through with your swap. I see you bought the Hookers. Looks good!! What size BB are you going to end up with?
Boo.
Boo.
thanks, i am building a 454, but i also am building a 400 sbc that i might play with. i am trying to find a t-10 set up for it now of go with a gforce t-5. i wish i would have bought the headders you picked but i had already bought mine. the hookers fit well. did not have to use the hammer too much.
keene
keene
Car: 1989 Camaro RS
Engine: 396 BBC
We'll see just how good my headers work when I go to put an exhaust system on it. I will still probably have to route it to the outside like the Hookers do.
Are you going to run a fiberglass cowl hood?
Boo.
Boo.
yup...pin on prob.
i was wanting the side exhaust . so they will work fine for me. it was kind of a pain to hold the headders and lower the engine by myself. i had bungee cords holding them up hanging from the strut mount.
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Originally posted by ckeene502
yup...pin on prob.
yup...pin on prob.
blackroc86.... what problem did you have, mine was not to bad on the passenger side. i hope i did not overlook anything. although i did noticed they are kinda resting on the cross member too much i thought.
Car: 1986 Iroc
With the slip tube out I still didn't seem to have enough room to slide the header up into position. The number 4 tube would hit the k-member before the back could go up. I ended up pushing a little crease into the firewall to allow the back of the flange to clear the firewall.
I guess it wasn't all that bad but the instructions left a little to be desired.
redformula88
Oct 14, 2015 06:08 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
