Another 305 to 350
Old Aug 21, 2005 | 11:49 AM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
Another 305 to 350
For anyone who might remember the 305, I've blown it up, and moved onto a 350.
Edelbrock 1406 carburetor, Holley Intake Manifold, stock everything else.
For the most part it is running well, I got it up to 110-120 on the freeway yesterday, and it felt like it was still accelerating.
But my problem is the initial acceleration. The 305 had great torque, and when stomped on from a dead stop, would almost "take a breath" and then just start screaming. That engine could hold it's own against a lot of cars, until they caught up, and beat it. But the launch was good.
The 350 however doesn't really accelerate quickly. It takes it's time, and really hauls *** in terms of top speed, but it doesn't launch well. It doesn't even do the "taking a breath" thing that I liked about the 305. It just starts to go when you floor it, and goes equally as fast at about 1/2 throttle, or 3/4 throttle. There isn't a difference in launch speed.
So. Do you think this is Carb related, a timing issue, trans, all of the above, or something different all together?
I appreciate any input, and thanks again for all the help.
This place made all of this possible.
-Chris
Old Aug 21, 2005 | 02:52 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you'll get better help in the carb section. the 'take a breath" is it bogging, then it catches up. the just as fast @ 1/2 & 3/4 throttle, could need som enew secondary rods, but since I haven't needed to worry about carter/edelcrotch carbs I'll say no more. Also check that your throttle plates are opening fully when the go pedal is mashed.
Old Aug 21, 2005 | 04:25 PM
chevymetal's Avatar
Yeah, they definately open all the way, I checked that when I adjusted the TV cable, wanted to make sure it was actually reaching WOT.
But you say it sounds like the carburetor for sure?
I'll post over there too.
Thank you!
Old Aug 22, 2005 | 11:49 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
classic rochester quadra-bog
Old Aug 23, 2005 | 12:24 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally posted by chevymetal
...Edelbrock 1406 carburetor..
How so?
Old Aug 23, 2005 | 12:28 AM
montesa311's Avatar
lol, whoops missed that part... is that vac secondaires?
Old Aug 23, 2005 | 12:30 AM
five7kid's Avatar
Yep. Non-adjustable.
I seriously doubt it's the carb.
Old Aug 23, 2005 | 01:51 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
I'd look at the timing. Infact bring it up ( Advance it ) till it pings and take it back a bit and see where your at.run it there and see how it performs. if it's really high you might have an advance issue or a spun balancer.
Old Aug 23, 2005 | 06:59 PM
chevymetal's Avatar
I checked the timing, and it was at about 12 so I've got it at what I think is around 6 and it's doing a bit better.
By balancer are you talking about a harmonic balancer?
And pardon my ignorance, but what does "spun" mean in whatever you are referring to?
I was looking at some MSD distributors yesterday, and I'm wondering if it would be worth the cash. Right now I'm running a J-Yard distributor, and I think that may be an issue.
Probably the weakest link on the engine.
I'm definitely still learning.
Old Aug 23, 2005 | 08:03 PM
Car: 90 Formula
Engine: 355 C.I.
The balancer is basicly 2 pieces of steel with a rubber issolater ring between them. I've seem many that the outter ring turns on the rubber which misaligns the timing marks. I've seen them spin and slide back into the timing cover and wear a hole in that too.
Old Aug 24, 2005 | 03:42 PM
chevymetal's Avatar
Any way to check if it's bad?
Old Aug 27, 2005 | 12:53 AM
Car: 90 Formula
Engine: 355 C.I.
see if it's slid backwards toward the ting cover - bring #1 to TDC and see if it's where it looks to be right
Old Aug 28, 2005 | 11:50 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
btw.... the 1406 is a mech secondaries carb. I ran one til i pulled my motor.
Old Aug 29, 2005 | 12:42 PM
five7kid's Avatar
Technically, it is not. It has mechanically actuated butterflies on the throttle body, true, but air flow is controlled by a demand-base "air valve" above the TB. A mechanical secondary carb only has mechanically opened butterflies, no demand-based control.
It may not be totally accurate to call Edelbrock's "vacuum secondaries", but it is even more inaccurate to call them "mechanical secondaries".
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
