Is there a bigger engine?
Old Aug 26, 2005 | 05:04 AM
kariya762's Avatar
Is there a bigger liter engine of the V6 instead of the 3.1L?
Old Aug 26, 2005 | 05:20 AM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
yeas the 4.3 v6
Old Aug 26, 2005 | 07:28 AM
net_coma's Avatar
I am not a V6 database but isn't the 4.3 block assembly different? Would his fuel injection and etc. be compatable with the 4.3?
Old Aug 26, 2005 | 08:07 AM
ND4SPD86's Avatar
It might be I never relay tore into either one so the best avdvice I could give is check out the v6 section and do a search
Old Aug 26, 2005 | 10:02 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
3.4
Old Aug 26, 2005 | 10:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The largest Chevy 60 degree V6 is the 3.4. The 4.3L is a 90 degree V6 based on the small-block V8 (imagine an SBC with two cylinders chopped out of the middle). There's also the 3.8L Buick 90 degree V6.
Old Aug 27, 2005 | 08:23 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
^^ and the Buick Series II V6 has the 60* bell housing bolt pattern.
Old Aug 27, 2005 | 12:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
the 4.3 V6 is based on the SBC... its litterally a 350 with 2 cylinders left in the dust.
Old Aug 28, 2005 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is also a 4.1L Buick 90 degree V6.
But the only one that the originator should investigate is the 3.4L V6.
Getting one in place of your 2.8L or 3.1L is covered on the V6 forum.
Old Aug 28, 2005 | 01:26 PM
cdartz's Avatar
The 3.4 liter is the one you want. It's a really easy swap to do. I helped a friend put one in a Firebird a few years back. Basically everything from your 2.8 will bolt right up. I'd recommend having a custom chip burned to compensate for the extra displacement.
Old Aug 28, 2005 | 04:03 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Just out of curiosity how is the 3.8 different. And I mean a 3.8 out of a camaro, boniville ect.
Old Aug 28, 2005 | 04:11 PM
Engine: 5.7 / 7.4
shoot me a pm, hit me up on AOL IM XaefodBebolbrox, or just do a search in this or V6 forum on "3800". I did the swap, had it running, ran into some PCM fuel enable issue, and am swapping it out (not really by choice, but answers are in this site somewhere)
click on my web site link, I have pics of my 2.8~3.4~3800 swap. No 3800~305 pics posted yet. I'll save that for when it's done.
Old Aug 29, 2005 | 09:04 PM
A_T_F_B's Avatar
thats not true persay, the larges stock 60degree is the 3.9, the 3.4 is the biggest your going to get as far as RWD, but i think there might also be a 3.6 DOHC RWD 60degree also but thats would be too big of a pain to swap
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
InfinityShade
Aug 22, 2015 08:00 PM
Cameeeero
Aug 20, 2015 03:06 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
