2.8 to 3.1? Whats involved?
Old Oct 8, 2005 | 04:20 AM
ToocoolZ28's Avatar
Car: 92 RS V6 and 95 Z28 Convert. 66 Nova SS and 70 Chevelle SS396- 5 speed
Engine: 3.1 in the RS, 5.7 in the Z28
Transmission: Auto in the RS, T56 in the Z28
Hey guys, new member here. I have 92 RS with a 3.1. 70,000 miles on it that was wrecked and totalled last week. I'm buying an 89 Camaro that is VERY nice but has a tired 2.8 in it, both auto's. What problems will I have swapping in the 3.1 from the 92 RS? Oil pan? Exhaust? Most important are all the accessories and computer. Which computer to use? Anything I'm overlooking here? It HAS to pass emissions here.
Thanks.
Ron
Old Oct 8, 2005 | 10:20 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the only difference in the two is the crank. what i would do is grab the longblock from the 3.1 (this would be heads/block/crank/pistons/rods/cam) and put the 2.8 induction and computer on it. when you do this though i suggest putting at least a new timing chain on and going through and replacing ALL gaskets.
Old Oct 8, 2005 | 12:39 PM
ToocoolZ28's Avatar
Thanks, I didnt know they were basicly the same engine. The 3.1 only has 70,000 miles on it and has been driven by my sister and then my daughter since it was new so I dont know if I will change the timing chain, but I WILL change all the gaskets since it does have a couple of oil leaks.
Thanks again.
Ron
Old Oct 8, 2005 | 01:49 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
change the timing chain. If you've never seen an old one, the stretch will amaze you, plus it's really cheap. It will also take the slop out of the timing.
I think the 3.1 uses a knock sensor, but not sure. EGR valves are different so reuse the 2.8 one, just swap over the stalk it sits on. exhaust manifolds are the same, so exhaust is a non-issue.
Be careful of all that wonderful factory hard plastic line ou have to deal with.
Old Oct 9, 2005 | 07:55 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
Yup, pretty straight forward swap. If you jump on the v6 board you'll find out tons of info on this or the increasingly popular 3.4 swap. Even though this is the engine swap section the real experts on the V6 swaps are in v6 section.
Oh, and welcome to the board
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
