4cyl --> 350
Old Nov 13, 2005 | 12:58 PM
4banger82's Avatar
Car: 84 camaro F41
4cyl --> 350
im looking to swap a 350 in for my 4cyl. are the engine mounts different or could i just get the ones with the engine and drop it in? or would i simply be better off getting rolling body that had a V8 and putting an engine in that?
Old Nov 13, 2005 | 08:56 PM
Doom Sayer's Avatar
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
What kind of 350 are you wanting to put in?
I'm not too familiar with those 4cyl cars so I'm not sure what else you need to change over. But you defiantly need new motor mounts, trans, computer, wiring, etc etc. I'm not sure about the rear or anything else. Hopefully someone who knows more about this can give you more information.
It all comes down to what kind of budget you are working with. Some cases it would be cheaper and easier to just sell your car and buy another third gen with a 350 already in it...
Old Nov 13, 2005 | 09:26 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
With GM's "legendary" interchangability, it'll probably fit right in to the engine compartment, but I'm about 99.999999% certain the transmission will not match up.
Old Nov 13, 2005 | 09:39 PM
4banger82's Avatar
Car: 84 camaro F41
i just swaped in a T5 from an 83 TA so it might match up.
Old Nov 16, 2005 | 06:14 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
The transmission will not fit. You will need a V8 bellhousing.
Old Nov 17, 2005 | 04:29 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
This is the same swap I eventually want to do with my Duke: 4 banger --> Goodwrench crate motor. I'll also have to do a tranny swap, but can't decide between another manual or vert to a 700R4 or TH350. If you do yours soon, 4banger82 , keep us posted. Maybe you can be the "giunea pig" and I can learn from you.
Old Nov 20, 2005 | 12:39 PM
Nighthawk 91's Avatar
Car: 1991 Firebird
Engine: L-slow-3
Axle/Gears: 3.08
If you swapped a T-5 from an 83 TA then that should fit. That IS a V8 bellhousing because the only engine that came in an 83 TA was the 305 V8. One thing to keep in mind is that the clutch is hydraulic on 84 and up and not on the 83.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
