question about compression
Old Nov 18, 2005 | 09:37 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
ok, swapping the 305 out and putting in a 355 i'm currently assembling. I just figured the compression ratio to 11:1. I have aluminum heads. Is this too high compression for premuim (93) pump gas? or should I be ok?
Old Nov 18, 2005 | 11:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Depends on the cam you have, but 11:1 should be ok... very borderline, but should be ok.
Old Nov 19, 2005 | 07:37 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
cam is: 224int/231exh duration at .050. .520int/.515exh lift, 113 degree lobe separation, computer controlled cam, from the comp cams new XFI line.
Old Nov 19, 2005 | 01:16 PM
Air_Adam's Avatar
I don't have much experience with computer controll, but judging by that cam, 11:1 might be kinda high... If possible, a cam with more duration and overlap would help alot. Whats the manufacturer's rec'd compression ratio for that cam?
Old Nov 19, 2005 | 01:25 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
it's a hydraulic flat-tappet cam btw, forgot to mention that. I'll hafta look up the recommended CR and post when i find it.
Old Nov 19, 2005 | 05:11 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
You want a roller cam, not flat-tappet.
Old Nov 19, 2005 | 06:50 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
it's not a roller motor, it's a 77 SBC 350 bored .030 over.
Old Nov 19, 2005 | 07:06 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It's a little too high for pump gas. I'd go 10.3:1 max.
Old Nov 20, 2005 | 03:47 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
well I'm screwed then, unless i get different heads.
Old Nov 20, 2005 | 09:25 PM
Air_Adam's Avatar
Not necessarily... what head gasket thickness did you use in the formula when you got 11:1 CR? Using a thicker one can drop CR quite a bit. 10.5 CR would be fine with the right cam and aluminum heads.
Old Nov 20, 2005 | 09:59 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
i used .041 gasket in my calculations. how much thicker do they come?
Old Nov 21, 2005 | 12:15 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
ok, i found some gaskets to put me right where i need to be, I was only looking at fel-pro before, thx for pointing me in the right direction, Air-Adam, you're officially my new automotive hero.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
