LC2 3.8 Turbo swap
Old Nov 13, 2005 | 07:27 PM
transformula87's Avatar
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
LC2 3.8 Turbo swap
Has anyone swapped a LC2 Motor into their 3rd gen? Will it fit easily? what about 5 speed tranny?
Any information is greatfull...
Old Nov 13, 2005 | 07:54 PM
TexasLT1's Avatar
Car: '92 RS
yeah, gm did it in 1989. Its called the Turbo Trans Am.
Old Nov 13, 2005 | 07:57 PM
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
yeah i knew that GM did it... i was looking more for someone swapping one into theres.
Old Nov 13, 2005 | 07:59 PM
TexasLT1's Avatar
Car: '92 RS
sorry, was just in a smartass mood
I know its been done. just do a search for TTA or grand national motor swap
Old Nov 13, 2005 | 08:20 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
lol
Old Nov 13, 2005 | 08:26 PM
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
havent found anything on the mounts...
Old Nov 13, 2005 | 10:01 PM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
Look no further than the FAQ on this board......
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Search for "3.8" and it will jump you right to what (I think) you're looking for....?
Old Nov 14, 2005 | 02:08 PM
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
sounds hard enough to just find the parts. Well, its still in my mind. I'm just tired of seeing 3rd gens with 350 crate motors in them....it gets really borring
Old Nov 14, 2005 | 03:16 PM
TexasLT1's Avatar
Car: '92 RS
if you want to spend the money just to be different, go right ahead.
Old Nov 14, 2005 | 04:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Go Indian, then.
Seems to be the only "right" way to some 'Bird owners.
Old Nov 19, 2005 | 03:15 PM
ronbuick's Avatar
Car: 87 Turbo Regal 11.78@115
Engine: Buick v6
Transmission: 2004r
I'm new to this board and I would like some info on this as well, as I'm also very interested in doing this to a 86 T/A, all help would be appreciated in this endeavor.
Ron
Old Nov 27, 2005 | 04:40 PM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
Transmission: GM 2004R
Tons of people have done the 3.8 swap by using a GN engine, removing the AC, using a 700R4 and a common stock 3rd gen rear.
There are a few threads over on turbobuick.com in the TTA section and the hybrid section to help you out.
The general consensus from TTA owners though is to do it right (eg to mimic a TTA in all aspects) it's cheaper to buy a TTA.
The engine is not a regular GN engine.
The heads, valve covers, down pipe, motor mounts, crank, pistons, transmission, drive shaft, AC lines, intercooler, intercooler shroud, fuel pump, fuel pressure regulator, drive shaft, computer (chip), MAP, engine wiring harness, gages and front springs are not GN or standard V8 F-Body parts. The TTA's rear end is also the 3.27 Borg Warner 9 Bolt rear and TTA's had 1LE Brakes.
(both relatively uncommon in most 3rd gens)
Have fun
Old Oct 25, 2006 | 05:44 PM
Calico's Avatar
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
well it will never really be done right becasue its not a real tta...lol my buddy has a nice one. I'm getting ready to swap my lc2 drivetrain in a really clean gta.
I plan to re-use my gta rear and get 3.42 gears, 700r4 and an ls1 aluminum driveshaft. I removed the a/c a while back and I will use all the gn's parts and get a downpipe made. I don't predict it being to god awful hard
Old Apr 4, 2007 | 04:10 PM
bender63's Avatar
Re: LC2 3.8 Turbo swap
Just saw mounts today after doing a google search on the TTA it just said mounts I think they were about 239.00 but could handle up to like 1000hp
AussiePr0nCar
Mar 6, 2020 04:04 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
InfinityShade
Feb 21, 2016 01:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
