350 tpi or 350 carb'd?
Old Nov 22, 2005 | 03:11 PM
87_CAM_F41's Avatar
hey, i just bought a 1987 Camaro w/ the F41 package, 305 LG4, 4 speed auto...im planning on swapping in a 350 tpi or 350 carb'd engine, but i have a few questions... the questions are:
1) Which engine would be easier to swap???
2) Which would make the most hp & tq???
3) What all would i need to get, in order to do this swap???
thanks in advance
Old Nov 22, 2005 | 04:40 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Carbed would be easier. Personally I like fuel injection and will never put a carb on another one of my vehicles. Power wiese depends on them engine. Are you building an engine? Buying a used or new engine? Depending on what you want to reuse you wont need that many parts. I guess I need more info on what your goals are.
Old Nov 22, 2005 | 05:52 PM
87_CAM_F41's Avatar
i like fuel injection better, but idk how much time would be involved to do this swap, only bad thing bout tpi's are that they tend to loose power at 4k rpm's..id be buying a used engine..my goal is to hopefully have 500+ rwhp & rwtq, if its possible
Old Nov 22, 2005 | 06:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1st, you need to be realistic. 500 RWHP & RWTQ from a used engine isn't.
2nd, the easiest way to put in a used 350 would be to put the longblock under your current control system. You can use an aftermarket intake manifold if you want, which might be wise if your used engine is '86-earlier, although not a problem if it is '87-later (and not Vortec heads).
If you don't have plans to spend about $1000 on exhaust upgrades, start making them now.
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
