solid mounts?
Old Nov 27, 2005 | 07:51 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
solid mounts?
i am putting a 383 with around 450 fwhp and i was wondering if there would be any benefit to using solid motor mounts.
Old Nov 27, 2005 | 08:56 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
If you are using fuel injection then don't do it. There is a strong possibility that is will interfere with the operation of the knock sensor and cause false readings and alter your fuel and spark timing. Otherwise, I don't see why not. I can't say this with any certainty but I have had friends that made the mistake and they could never get the computer to stop retarding the timing without totally disabling the spark retard setting.
Old Nov 27, 2005 | 11:08 PM
MaNiAk86's Avatar
Car: 1983 trans am
thanx for the info. im goin with fuel injection so ill just use urethane mounts.
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
Stryker412
Sep 7, 2015 09:11 AM
FormulasOnly
Sep 6, 2015 10:42 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
