383 bare block
Old Feb 18, 2006 | 09:09 PM
Thomas77's Avatar
Car: 1988 IROC-Z
Engine: 355
Axle/Gears: 9 Inch 4:11
383 bare block
Has anyone used the Sallee Cherolet 383 bare block PN# 88962516?
Was there any other work needed to be done to the block?
Is it worth $870 or would I be better off buying a 350 and getting the block work done?
Old Feb 18, 2006 | 09:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It would depend on how much you could get a used block for, and how much machine work it would need at what price. It would also depend on how much the new block cost to ship to you.
Old Feb 18, 2006 | 09:54 PM
Thomas77's Avatar
Car: 1988 IROC-Z
Engine: 355
I can get a used block (350 4 bolt 1-piece) for $300 that I could pick up. What is the going rate for the machine work to make it ready to build a 383.
Old Feb 18, 2006 | 10:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd have to ask the local shops. Figure on boring, align honing, milling the deck and some clearance work for the stroker crank.
Old Feb 20, 2006 | 07:20 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
A general off the hip standard block prep price is right about $500-550 to have it done right. Alot of times your better off going local if you have reputable shops as opposed to buying from far away in the event of a problem, locals are more eager to help/replace/repair than a shop far far away...not to mention helping your local economy.
Loudnproud86
Jul 14, 2016 12:59 AM
RyanJB
Sep 14, 2015 03:39 PM
Kenwood
Sep 11, 2015 12:50 PM
