impala 350
Old Mar 11, 2006 | 03:33 PM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
impala 350
will a 350 out of an impala bolt into my 92 camaro
Old Mar 11, 2006 | 07:48 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: impala 350
Yes.Now,what year Impala?It's possible to bolt any 350 in,making everything else work can be a different story.For example,if it's an LT-1 from a late model,theres extensive work involved.
If it's an early 350,there can be several hassles to make your fuel injection jive with the rest of the engine.
Old Mar 12, 2006 | 12:13 PM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
out of a 63 impala
Old Mar 12, 2006 | 03:38 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Yes, that will be a direct bolt in, assuming you already have a V8.
Old Mar 12, 2006 | 03:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
'63? How sure are you this is a 350? The 350 didn't come around untill 1967, and wasn't used commonly untill 1969 and after...
Old Mar 12, 2006 | 04:38 PM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
thats what the guy told me it came out of
Old Mar 12, 2006 | 04:55 PM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
well i guess heres my new question will any chevy 350 thats older than my car drop right in with no modifications.
Old Mar 12, 2006 | 05:28 PM
Air_Adam's Avatar
Any 350 will drop in, but to put a pre-87 engine in your car, you'll need to work out something with the dipstick, as its on the opposite side from the '80+ engines, and interferes with stock exhaust manifolds. Also, before '86 had a 2pc rear main seal, which uses a different flexplate/flywheel.
Old Mar 13, 2006 | 09:42 PM
Coach Hawk's Avatar
For postarity, the 55-56 SBC will not bolt in because it uses a front mount instead of the standard side mounts. Other than that, all engine mounts and trans bellhousing patterns are interchangable up until the LSx series motors.
Old Mar 13, 2006 | 09:56 PM
ljnowell's Avatar
i dont know about the engine mounts, but the trans bellhousing will bolt up ok on the LSx engines
TX-SleeperC5
Feb 24, 2016 01:34 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
