distributor Wireing
Old Mar 13, 2006 | 01:11 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
distributor Wireing
Ok i finaly got my engine and trany in. I will be rewireing my engine. I got everything pretymuch figured out but i am lost with the distrubutor. I have a HEI with an accel super coil. I understand all the coil and tack wireing but my distributor has 2 plugs that come out the left side that i have no idea what they do.
thx
Old Mar 13, 2006 | 07:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you mean the distributor itself has two plugs, or the distributor cap?
Old Mar 13, 2006 | 09:17 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
The dristributor itself has plugs coming off of it.
Old Mar 13, 2006 | 09:23 PM
five7kid's Avatar
If your q-jet is non-computer controlled, you need a vacuum/mechanical advance distributor to go with it.
If your q-jet is computer controlled, one of the connectors goes up to the cap, and the other to the wiring harness on the firewall.
Old Mar 13, 2006 | 09:26 PM
five7kid's Avatar
Something tells me you have a mis-match of parts. A q-jet is not a q-jet is not a q-jet, and an HEI is not an HEI is not an HEI.
You probably want non-computer controlled equipment (guessing, since your car is an '89 in which no carbs were available), so make sure that's what you end up with.
Old Mar 14, 2006 | 12:24 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well the engine came out of a early 80s truck. It was running with a non cc q-jet. The distrubutor has vacume advance on it that is why i am confused. I thought you only needed to hook up the vacume advance and the power to the coil. I will get my friends camera and take a picture of it later on if it helps.
Caspar
Jun 19, 2016 11:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
