How to go low 12's
How to go low 12's
I want to got low 12's what the cheapest way to do this? In my 86 z28? It has a 350 in it right now it mine make 150 to the wheels LOL. I was thinking a 400 small block but can a 355 take me to 12's?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: How to go low 12's
Re: Re: How to go low 12's
Yea I know it takes more than just an engine to run low 12's. What I plan on doing 1st is the engine. What kind of power would I have to make to get my car there? What parts would I need to get there? The car will be a 5 speed. This will see the street a few times a month and just a few track runs a year. If some one could give me a build sheet on this just to give me an idea. I want to get the best bang for the buck. I dont want the cheapest parts and I dont want the most price. Just some thing I can take to the track and run some pretty good times in a drvie home. Thanks
Originally posted by ShiftyCapone
Your 350 can take your current into the 12's. Running 12's doesn't happen with a few parts. It takes a balance of parts and special attention to the small things not associtated with the motor. You need a good set of gears with a limited slip. You need proper suspension parts to maintain traction. You need a free flowing exhaust from the headers back (3" +). From there you can focus on the motor. You will need to look into a heads and cam swap. 400hp can propel a 3rd gen into the 12's. Your 350 is very capable of making that with the right parts.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Engine:
10:1 c/r
113 aluminum cylinder heads from a vette w/ mild bowl blending
crane power max solid lifter cam: 238/248@.050 .480"/.500"
comp pro magnum roller rockers 1.52:1
hedman longtube headers w/ dual 2 1/2" pipes (i think it could use dual 3")
holley 750 double pumper
holley street dominator intake (the bigger of the two, idle-7200)
Tranny:
700r4 w/ transgo shift kit, rebestos clutches and bands, hardened sunshell
4000 stall 10" ATI converter
rearend:
4.10s
eaton posi
aluminum diff cover
WEIGHT REDUCTION:
manual steering
fiberglass hood
aluminum pulleys
obvious emissions delete
aluminum weld wheels
Suspension:
lca relocation brackets
boxed stock lca's
spohn non adj panhard rod
poly bushing for the stock torque arm
M/T ET Street radials 275/60/15
v6 springs
no front sway bar
car went 12.34@109mph on a 1.64 60'.
10:1 c/r
Tranny:
rearend:
4.10s
eaton posi
aluminum diff cover
WEIGHT REDUCTION:
manual steering
fiberglass hood
aluminum pulleys
Suspension:
boxed stock lca's
v6 springs
no front sway bar
Your the man!!!! Thats what Im looking for. Thanks
Originally posted by mw66nova
Engine:
10:1 c/r
Tranny:
rearend:
4.10s
eaton posi
aluminum diff cover
WEIGHT REDUCTION:
manual steering
fiberglass hood
aluminum pulleys
Suspension:
boxed stock lca's
v6 springs
no front sway bar
Engine:
10:1 c/r
Tranny:
rearend:
4.10s
eaton posi
aluminum diff cover
WEIGHT REDUCTION:
manual steering
fiberglass hood
aluminum pulleys
Suspension:
boxed stock lca's
v6 springs
no front sway bar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
finally got it all tuned up and at the track eh? That's pretty awesome there nova, i'm impressed.
Any guesses as to HP? How's the vacuum with that cam? Ok for brakes?
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
How much do the LCA relocation brackets help?I'm all for a drop in 60' times,and thats about all I haven't tried.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Originally Posted by unknown_host
350, 9.9:1, Vortec Heads, XE274 flat tappet cam went 12.28 @ 111.85 weighing in at 3100 w/o driver.
Engine: 7.0L
oh oh, new times: 12.16@110mph on a 1.65 60'. pulled the broken 4.10 rear out of the car and put in my spare 3.73 open diff. disc rearend to get me to work and back. this rearend has no lca relocation brackets, so even with the 275/60/15 M/T ET STREET Radials i had to feather the gas to not wheelhop so it's got more in it once i get the "good" rearend back together(with a new set of 3.73's, seems to like it more than the 4.10s). i also played with jetting and pumpshot and got the bog out of her, but i forgot my air pan that seals the carb to the cowl hood, so i know it's got more in her when i get a rearend that i can beat on out of the hole.
hello 11's.
according to my speed/weight, i'm making roughly 428hp at the crank. and it's extremely streetable with my 114lsa. thank you so much F-Bird '88 for the help on cam selection.
hello 11's.
Wow seems to be working very well for ya. Maybe I'll have to order one of those cams up for the 406. I think your ATI trans and converter has a lot to do with it. ATI builds a hell of a good converter. What is your 1/8th mile time and MPH? What does the tach read (rpm) as your cross the finish line? The best 4.10 gears you'll find come out of factory GM 4 cylinder S-10 rear ends. Special hardened alloy. Superior to the the aftermarket stuff.
Kinda new that Crane cam was a winner. Its been around forever. probabily over 25 years. Just needed the right person to say to "this is the right cam for you"
Your car seemed just right.
Engine: 7.0L
1/8 mile was a 7.71@88.11mph
going through the traps with the 3.73's around 5500rpms. i really like the 3.73's. i've already seen a dramatic improvement in fuel economy and it still drives around town the same, and it seems to be quicker on the track too. definitely gained a solid MPH too.
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
Just one suggestion the T-5, 5 speed wont live with the kind of HP it takes to go 12s you would be better off with a auto trans ...plus it's usually more consistant...
