1987 Camaro Coupe
Old Mar 20, 2006 | 07:51 PM
CrOaKeR3's Avatar
Car: 1987 Camaro Coupe
Engine: V-6 2.8
Transmission: Stock
Axle/Gears: Stock
1987 Camaro Coupe
i jus got a 1987 Camaro Coupe with a 2.8 V6 Fual Injet and i want to swamp a 305 V8 carb into it! what will i need to change to my car to put the 305 into it! will i need a new tran or a new rear? i need to no what all i need to do!
Old Mar 20, 2006 | 10:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/techbb2/sho...d.php?t=229665
https://www.thirdgen.org/tech/carbswap.shtml
Old Mar 20, 2006 | 10:28 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Start by reading the sticky posts at the top of this forum (of all places), and if that doesnt answer your questions, try a
THEN post new questions
Old Mar 20, 2006 | 10:30 PM
CrOaKeR3's Avatar
Engine: V-6 2.8
Transmission: Stock
Axle/Gears: Stock
i read it and dont get it from what i was told i can take my 1987 Camaro Coupe and take the 2.8 out and jus get new mounts for the 305 keep same tran they said it will hold as long as i dont beat on it!!!
Old Mar 20, 2006 | 11:08 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
If the transmission you are using didn't come from a 3rd or 4th gen f-body, you're going to need some means of mounting the torque arm. B&M makes a bracket that uses the tailshaft housing mount bolts for a TH350 or TH400. A good upgrade is a crossmember/torque arm kit from our site sponsor Spohn (see button above). The TH700 tailshaft housing can be swapped, so if you have a non-f-body TH700, you can put an f-body housing on it.
Id identify my transmission, if I were you.
Old Mar 20, 2006 | 11:19 PM
CrOaKeR3's Avatar
Engine: V-6 2.8
Transmission: Stock
Axle/Gears: Stock
its 3rd gen tran so it should hold a 305 as long as i dont beat on it!! if so can i jus get a 305 motor complte carb and drop it in
Old Mar 20, 2006 | 11:42 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
nope, the v6 trannies have a 60* bellhousing and will not bolt up to the back of your 90* small block chevy. you will need a v8 transmission. i suggest getting a rebuilt 700r4 if it's going to be on the street.
other than that, you'll need to put in a new set of motor mounts, exhaust(good time to go to headers and aftermarket catback) i'd look at the hooker 2055 headers and a flowmaster forceII catback. this would rumble really well and get you "exhausted" for about $650...so it's not TOO expensive.
from there, the rearend will work just fine. actually, you have 3.42's in the car right now and it'd be a great all around gear. kinda middle of the road w/ advantages of performance and streetability.
a set of subframe connectors will be in order as all of these cars flex WAY too much even with the puny v6's.
fuel system is fairly simple. if you want to keep your intank pump, just put a regulator (assuming your going carb) at the front of the lines. something like the mallory 3port regulator so that you can return all the unused fuel. carbs only require about 4-6psi, that intank pump puts out closer to 50psi, you will have to regulate it or you'll be shooting fuel out the top of the carb. the other option is to drop the tank, pull the intank pump out, extend the pickup using a piece of 3/8" tubing and a compression fitting, putting the tank back up. remove the inline fuel filter with another piece of 3/8" tubing and two more compression fittings, then install a mechanical pump and pushrod for a 1985 lg4 camaro. this is what's feeding my low 12 second car.
while this post is relatively vague, so is your original questions. if you have any more questions about anything specific, feel free to PM me.
just FYI, get ready to drop about $3k into this thing for all the necessaries
Old Mar 21, 2006 | 03:44 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
where you at? i have a 305 in my garage in western new york state. let me know if your interested
Old Mar 21, 2006 | 10:33 PM
CrOaKeR3's Avatar
Engine: V-6 2.8
Transmission: Stock
Axle/Gears: Stock
yes is it carb or fual injet? how many miles? Will it start right up? were is motor from and what year is motor?
Old Mar 22, 2006 | 07:59 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
carb, about 100K, engine came from a friends 86 bird. it will fire right up, ive got an earlier one wire hei for it so you dont need a computer. it was the first 8 i put in my car but i wanted more power so after i got everything converted to v-8 from the six i put a crate engine in my car. he did the same thats why he sold it to me.
Old Mar 22, 2006 | 07:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If going to the trouble of a v6 to v8 swap, why not drop in a 350? You'll spend the same money either way, and have a helluva lot more fun with the 350! I have a 305 and a 350 - and I definitely wouldn't waste my time swapping in a v8 without going 350!
Old Mar 23, 2006 | 10:46 PM
CrOaKeR3's Avatar
Engine: V-6 2.8
Transmission: Stock
Axle/Gears: Stock
bc of gas prices
Old Mar 24, 2006 | 10:05 AM
mw66nova's Avatar
Engine: 7.0L
Originally Posted by CrOaKeR3
bc of gas prices
with a carbed v8, your going to get crap mileage no matter what. my buddies 305 with a mild roller cam and edelbrock carb on it with stock torque converter and 3.23 gears is getting about 15mpg mixed city and highway.
my old 305 with a bit more cam, holley 650 double pumper, 4000 stall converter and 4.10 gears, i was managing 16mpg mixed. that motor was pushing roughly 340FWHP. took it on a trip and got close to 22mpg highway.
my new 350 has a bunch of cam, worked holley 750 double pumper, 4000 stall converter and 3.73 gears, i've managed a solid 14.5mpg mixed. this motor is making close to 450FWHP. this should net a solid 21mpg highway.
it's got alot to do with how you drive the car and how it's setup. the reason i've done so well is cause i'm easy on it puttin' around town, it has NO accessories on the front other than waterpump and alternator, and they have aluminum underdrive pulleys on them. went to a full manual steering swap, managed to get the car down to a solid 3000lbs w/o driver and i made sure i kept my lockup abilities with the converter.
now, if mileage is a REAL concern, stay with the v6, cause it will easily get you 25+mpg mixed with 30mpg a real possibility on the highway. if you want more power, look into custom fabbing a turbo system onto it. this can be done (if you have fab skills) for around $1k. look on the v6 boards on ways to do this. search for Doward and Techsmurf. there is another guy doing it too. or, the other option is to find a v8 car and start modding it like crazy and keep the v6 as a daily driver. this is the way i would do it if i had it to do all over again.(the last 3 cars i have had have been factory v6 cars and all ended up with v8's before i was done with them.)
Cleotiz
Jan 6, 2018 08:56 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
beachrodder
Aug 25, 2015 08:05 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
jahblah
Aug 12, 2015 05:54 PM
