305'ers out there - I need your help!
Old Mar 27, 2006 | 03:33 PM
RedOctober's Avatar
Car: '88 Sport Coupe - 383 Stroker
Hey all -
I have an '88 that I bought with no engine/tranny.
I'm beginning my non-TBI, non-smog, 383 build to drop in, and ran across something I hadn't thought about:
On what side of the car (driver/passenger) was the original dipstick?
Better yet - does anyone have decent pictures of their 305 TBI engine compartment that I can look at?
Thanks in advance!
J
Old Mar 27, 2006 | 03:47 PM
joneboyy's Avatar
Car: '82 Z28 Indy pace car
Transmission: 4 speed berg warner
passenger
Old Mar 27, 2006 | 03:56 PM
RedOctober's Avatar
Thanks, joneboy!
Follow up question:
What (if any) is the requirement for it being on the passenger side?
That was the other reason it would be nice to see pics of someone's engine compartment...
Thanks, all!
Old Mar 27, 2006 | 04:03 PM
headers
Old Mar 27, 2006 | 04:18 PM
joneboyy's Avatar
ya the headers
Old Mar 27, 2006 | 04:25 PM
RedOctober's Avatar
OK - sounds like "headers" is the right answer...
Given that - can I use a driver-side dipstick block?
I'll probably be using these Summit Racing headers.
Thanks in advance...
J
Old Mar 27, 2006 | 06:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My 350 has the stick on the drivers side - no problem with my headers - the only thing is you need a matching oil pan.
Old Mar 28, 2006 | 12:44 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
your building a 383, then going to restrict the crap out of it by using those junky 1.5" primary 2.5" collector headers? jeez, if you gotta use shorties, at LEAST use the hooker 2055's and give it some 1 5/8" headers. other wise, bite the bullet and either get a set of hooker or hedman longtube headers and run dual exhaust...
Old Nov 27, 2006 | 07:29 AM
Freak_Z's Avatar
Car: 1983 Berlinetta
Engine: Chevy 305
Transmission: TH-200
Axle/Gears: 10 Bolt - 3.73
Swaping engines form a 305 to a350 or 383 would be a definite good idea.
You would get more power with little hassle.
I would also suggest getting the 700R4 transmission, it has much better shift quality than the TH200.
Old Nov 27, 2006 | 04:57 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
I am running hedman LT's with a drivers side dipstick, I do have to remove the dipstick to pull the header out while the engine is still in the car.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
