Canton pan and Solid motor mounts
Old Apr 16, 2006 | 08:45 PM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
So i just installed a Canton oil pan and put solid motor mounts in. Now the pan was hitting the center link on the one side so idecided to put 2 washers on the block side of the mount to lift it off the center link instead of trying to dent the pan. Then i had to elongate the bolt holes. But it was a bitch to line the motor up and i just dont feel comfortabe doing that. I prefure to do somthing to the centerlink , would it be cool if i grinded down the area where it hits??? it just hits a scosh bit, i have the feeling that im going to pick up the motor and drop the center link and use a piece of pipe to dimple/dent the pan. What doyou guys thinki should do????
Old Apr 16, 2006 | 09:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
dent the pan, considering the motor will rock back and forth, not to mention grinding the centerlink isn't really a good idea, i'd want 1/4" clearance if not more between the centerlink and the pan just to be safe. motor will still twist a little regardless of the solid motor mounts, mine moves a bit under heavy throttle.
Old Apr 21, 2006 | 06:35 AM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
so i ended up denting the pan a lil bit and then took out the washeres that i used to shim it up, now there is a gap between the centerlink and the pan, oh and i waited like a tank of gas looking for a 20x1.5 plug to put in the canton pan, you can buy one from advanced auto for like $2.14, and this is after going to industrial supplie places that carry EVERYTHING!! well i guess not everything, i guess sometimes you just need to go back to basics
Old Apr 21, 2006 | 10:50 PM
chevy35086's Avatar
Car: Camaro z28 1986
Axle/Gears: 3.42's
canton racing has that plug that you need i believe it is 14 bucks shipped if you didnt already get one.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
