Help me choose a 350
Old May 14, 2006 | 06:21 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I have a 350 from a 87 suburban and a 350 from a 91 suburban.... which one you think i should use... I havent cracked open the 91 but according to the casting numbers it may have a roller cam, and a 4 bolt main.
and know nothing about the 87 yet since I havent quite pruchased it yet.
Old May 14, 2006 | 07:35 AM
dmenchaca's Avatar
you can put a roller cam in both of them. but as far as i know none of the truck engines came with roller cams.
Old May 14, 2006 | 09:27 AM
bretsk2500's Avatar
Car: 88 Chevy K2500
Engine: 350 TBI
Axle/Gears: 14b SF 3:73
but being a '87 or a '91 there's no saying that the original motor is in there. in my 88 truck I discovered at cam swap time that I had a re-man'd roller motor in it.
Old May 14, 2006 | 05:24 PM
dmenchaca's Avatar
87 up blocks are roller motors but the truck engines did not come with roller cams.
Old May 14, 2006 | 07:47 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Well I bought the 91 it is so seized with water I cannot even get the pistons out of the block.... its screwed... I guess I loss a 100 smackers... I will buy the 87 tomorrow....another 100 for that..
Old May 14, 2006 | 09:05 PM
bretsk2500's Avatar
Car: 88 Chevy K2500
Engine: 350 TBI
there was definately a roller cam in my engine, a crappy rolller cam, but a roller none the less.
Old May 14, 2006 | 09:36 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I have seen many,many 87-91 blocks that were cast for the lifter spider,but not machined or tapped.I don't know what it would cost to properly machine one for a roller cam spider,but it's definately something to keep in mind when shopping for a 1piece RM block.
Old May 15, 2006 | 05:08 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Doesnt matter both of the engines are junk... cant use them... one is seized the other threw a rod and that wont turn either after the rod was removed..
TX-SleeperC5
Feb 24, 2016 01:34 PM
89fast5oh
Sep 8, 2015 09:55 AM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
