bbc oil pan
Old May 29, 2006 | 06:13 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
bbc oil pan
hello- i've done the search and only come up with the chevelle pan. anyone use an aftermarket pan on the big block swap?i might be going with the 4.250 stroke. the crossmember is stock .
Old May 29, 2006 | 06:32 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I use the moroso 7 qt pan with no kickout, it`s clearenced for a 4.250 stroke
Old May 29, 2006 | 07:21 PM
craig's Avatar
Car: 86 camaro
thanks-good to know one will fit.
Old May 29, 2006 | 07:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depending what headers you're using. Most swap headers won't work with a kickout pan because they come too close to the sides of the pan. I also use a Moroso 7 quart pan. Any standard BBC car replacement pan will work with no problems. The performance pans should all be clearanced for a stroker crank.
Old May 29, 2006 | 10:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A Camaro pan should also work, at least for a stock stroke.
Old May 30, 2006 | 12:49 AM
AC398's Avatar
Car: Red 89 GTA
you dont have any ground clearance issues w/ the moroso 7 qt? I assume the 7 qt. hangs lower than a stock type oil pan. Im getting to the point where i need an oil pan for my motor and a chevelle pan from chevy is like 150$. I found 1 on summit a 4 qt. stock summit brand oil pan and am thinking about using that but would really like more oil capacity and was considering the moroso
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
