HELP PLEASE!!! FIRST TIME REMOVING A ENGINE
Old Jun 15, 2006 | 07:09 PM
diabolik's Avatar
Car: 1982 Pontiac Trans Am (Recaro)
Engine: 5.0 v8 (305 TBI)
I knew this day was to come like a Prophecy oil smoke coming from the back but no over heatin thank god! my engine now has oil coming from the head gasket and am now striping it down of all parts naming all wiring as i go along but this is the first American engine ive had to remove its a
305 V8 5.0Litre, Carb, Automatic Transmission
does any have any pointers on removing the engine should i pull the trany out as well? or would it be easier leavin it in or i have no choice but to pull that out as well, the manuals i have arnt that much help and should i be preparted for some shocks?
I know rebuilding this kinda engine is a waste but i live in the UK and this does me just fine havent had any complaints until now and keeps up with boy racers here but mainly used for crusin
P.S any idea where to get a good rebuild kit (basicly everythin pistions ect..)
Old Jun 15, 2006 | 07:42 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just get a big knife and cut everything in sight, I heard Walmart has a good rebuild kit for $12.86
Old Jun 15, 2006 | 08:09 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
305 rebuild kits are HIGH to HIGH I think $700 or $800
Old Jun 15, 2006 | 08:22 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You might be high, where did you get that price from???
Old Jun 15, 2006 | 10:13 PM
Hotdogstand's Avatar
If it's a third gen, I've read just to pull off the nose cone, and lift the engine out, take the trans if you want. Hawks Third Gen (online) or summit racing will have everything you need or want for a rebuild, depending on your budget.
Old Jun 16, 2006 | 03:18 PM
Car: 1992 camaro
Axle/Gears: 3:73
seen it here at local shop and in chpm
Old Jun 18, 2006 | 01:54 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Well so far ive done 3 thirdgen engine swaps so let me try to pass some knowladge across the pond to ya.....
Its easier to pull the motor/trans as a unit. Even if you separate it and pull just the motor, youre going to have a hell of a time trying to bolt a new motor on a tranny thats still in the car. Trust me, save yourself the headache and bloody knuckles and just pull it as a unit.
Also, get an engine hoist with a long boom, or youll have to pull the motor from the side of the engine bay. (the nose on our cars is a lot longer than it looks) Not to say that you cant pull the motor from the side of the car, ive done it. But once again, its a royal pain in the ****
Oh and once that 305 comes out, you may as well use it as a boat anchor, thats about all its good for. Trust me, build a 350 youll be much happier.
Let me know if you have any more questions
Old Jun 18, 2006 | 02:34 PM
trans_am_31's Avatar
Car: 85 Trans Am,79 Trans Am,02 Trans Am
Engine: 5.7 V-8 346 LS1
Transmission: Automatic
Agreed
Old Jun 19, 2006 | 03:18 AM
CrazyHawaiian's Avatar
Car: too many ...
You can get a rebuild kit through Summit Racing or Jegs. But before rebuilding anything I would run a compression/leakdown test on the motor while still startable, then take the motor out and disassemble it and see what is broken. No sense buying a complete rebuild kit if only the headgasket is bad (just an example). When I've removed engines it I've always pulled just the engine, no sense removing the trans if you aren't going to work on it. But thats just my opinion.
Old Jun 19, 2006 | 04:32 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
i am going to second (third actualy) what "StreetRoc85 350" said. if you are leaking oil from the head gasket, and the block itself is fine why rebuild it? just replace your headgasket, put it back together and flush your oil and coolant a few times. good to go.
and also, i know it may be difficult to find a good block over on that side of the atlantic, but if you have to rebuild, and you can get ahold of a 350 block you will not regret it. if in proper tune it will only get slightly less petrol effeciancy then the 305. and you will feel the difference when you hit the accelerator.
so, over here we say Miles Per Gallon (MPG) regarding fuel/gasoline consumption, do you guys say Kilimeters per Liter or somthing? do the english have an acronym for that? just wondering...
Old Jun 19, 2006 | 07:47 PM
diabolik's Avatar
well i finally got the bitch out thanx for the pointer StreetRoc85 350 found it alot easier than i thought just removing the engine and tranny as one unit, took longer though as every five sec kids coming up is that the car of knight rider and after 50 times sayin yes i thought i was turnin mad!! Anyway back to the engine the block seems fine after a blast clean came out nice and the oil was coming from the passanger side head gonna have a closer look tomorrow, when removin the valve covers the idiot that put them on put most of the gule on the tappets and the crap lyin around was a joke looks like hair or somthin this car has been abused why.. why bother why do people do this only peneys of gaskets ect.
Still thinkin of puttin a 350 in, will make my mind up tomorrow if its really bad, and Xophertony we use the MPG think the only things we do different is the temp we do it in oC and not sure but we do Miles and do you do Kilomiters? and drive on the other side of the road which when drivin an American car anit that easy even on roundabouts need a passanger to help out, one last thing what should the MPG ona car like this should be i think i was gettin about 15MPG and with petrol here being 97.9p ($1.78) not cheap to run, aways what the price their for petrol (gas)??
Old Jun 21, 2006 | 02:28 PM
Car: 88 IROC
Glad i could help. I know what you mean about driving an "american" car on the other side of the road. Believe it or not besides american muscle i also have a bit of an english fetish, that being MGs. My first car in high school was a 1957 MGA roadster (still have it). My dad has a 1948 MG-TC w/ right hand drive and it is a pain in the **** to drive around here on the wrong side of the car, esp when changing lanes....
Oh and btw, we use miles over here as well, its the canadians who are stuck on kilos..... Gas is about $2.75 a gallon over here and my 65mpg gixxer takes about $8 worth of gas to scoot me around for a week.
Old Jun 22, 2006 | 07:26 PM
diabolik's Avatar
well the heads are off that was fun ill sort some pics out tomorrow and the gaskets were gone no cracks in the head, but from the colour of the pistons a couple have been burin oil and two have a white chalk like substance on the piston heads (runnin rich?) also found more crap like hair and plastic bits and even some really think oil around the sump and the heads and a thick layer off somthing in the exhaust ports on the heads can be picked out by screw driver but no idea what it is?. Also why does the engine coolent turn a rusty colour in the block??
Old Jun 22, 2006 | 07:46 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Yes pull the tranny with the motor and If you want to rebuild a 305 so be it, dont let people talk you out of it. There are some people who have 305s that have awesome et's. I personally got rid of a 305 for a 350 but thats my preference. Keep in mind its cheaper to rebuild a 350 than a 305. and a 350 will always produce more Hp than a 305 with same components... but there is nothing wrong with a 305. Very respectable..
I hate you
Old Jun 22, 2006 | 10:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
We are a screwed up people here. Speed limits in km/hr, distance in km/hr. If I talk mileage to anyone, I convert to MPG. Usually american gallons, and not imperial gallons however. Outside temperature is in celsius, indoor (on my thermostat in the house) is fahrenheit. Flyers in the paper advertise meat at $/lb, in the store the signs show $/kg. Electronics are in metric, mechanical industry in imperial. I have to mill out an enclosure for a PCB, the electrical engineers speak metric, and I convert to inches so I can turn a dial on a milling machine. I'm seriously getting sick of being in purgatory here. DECIDE FOLKS!
/rant.
Gas is a solid $1/litre. In USA that would be $3.73/gallon, across the pond...?
anywho,
That's usually running LEAN. Rich would be black.
ugh! gross! Grab some engine degreaser and go to town! The crap on the exhaust ports, I could only guess would be old gasket material...? oh wait, IN the ports... ?
rusty coolant is pretty normal, based on what you've said so far. Sounds like the motor wasn't taken care of, and didn't have the fluids changed very often.
Check the bores, if they're *ok*, you could just hone it out, and put new rings and bearings and gaskets in the motor. Otherwise, see if you can source a 350 there. Shipping a 350 block across the drink would make a 350 swap MUCH MORE expensive then it is over here. I'd recommend building up the 305 in that case.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
